changng fork oil and...
- Treewizard
30 May 2011 18:15
didnt get verry far because right under the dust cap was a brass colored plug with a dimple in the mddle of it, can pop the plug down a bit with a screw driver but t dosent seem to be getting me closer to gettng t off
and of cource thr FSM just says 'tade it apart' and clymer isnt much better
unless im mssng something , how do get it further apart?
thanks in advance!
thanks in advance!
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
2002 ZRX 1200R
Raleigh NC
- wireman
Re: changng fork oil and...
30 May 2011 18:22
is there a snap ring of some sort you remove while pushing down on it?
- wireman
30 May 2011 18:25 - 30 May 2011 18:27Attachment 750fork.gif not found
look at #92033 in the picture where parts go through top triple tree,circlip
Last edit: 30 May 2011 18:27 by wireman.
The following user(s) said Thank You: Treewizard
- Treewizard
30 May 2011 20:54
crclip it is, so..
how do u get a circlip out that u cant see lol ?
ill mess with it tomorow
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
2002 ZRX 1200R
Raleigh NC
- Nebr_Rex
30 May 2011 22:12
Flat screwdriver should do the job.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- wireman
30 May 2011 23:53i dont know how to tell you for sure since ive never actually owned a 750 that had a set of forks that required you to push in on the little plug on top of fork tube while prying out the small circlip with a small straight screw driver like you would use to work on a thermostat while being carefull not to let the circlip fly away and get lost.Treewizard wrote: crclip it is, so..
maybe a more experianced person who understands how it works with actual first hand experiance could explain it.
if you need actual first hand experiance with removing a threaded in fork cap by all means ask away! :woohoo:
- Kidkawie
- I bleed premix
31 May 2011 08:09
Push the cap down until you see the clip, remove the clip with a pick.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
