KZ750B twin air box
- bikerjim
- 1986 T-type Regal
KZ750B twin air box
30 May 2011 15:06
I bought some clamp on pancake style air cleaners to replace the air box assembly. Could not figure out how to remove the box. Removed the battery holder assembly, but the air box still would not come out. How does one get that box out of there without tearing down the bike?
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
- steell
Re: KZ750B twin air box
30 May 2011 23:42
You can either remove the motor, or take off the rear wheel and fender, I've done it both ways.
- bountyhunter
31 May 2011 03:01They probably made it super difficult to discourage people from making the terrible mistake of going to pod filters.:woohoo:steell wrote: You can either remove the motor, or take off the rear wheel and fender, I've done it both ways.
- bikerjim
- 1986 T-type Regal
31 May 2011 12:37
Thanks. Yes, I would really rather keep the original set up, if new rubber tubes from carbs to box could be found. The factory rubber ones are still in use, but they are starting to crack from all that distortion and mangling when refitting them after cleaning carbs. Is there a source for them? Maybe I'm not doing a proper search. Thanks.
- 2Tired
31 May 2011 15:47
Hi Bikerjim,
I prefer the original intake set up over pods, too. There is an online store called Vintage Kawasaki parts (vintagekawasaki.com) The Kawasaki part number for the airbox connector is 11026-018. They are priced at $45.00 each there. That's a lot but if you need them, you need them. EBay is a good source for used ones. Some sellers list them with the airbox as a complete assembly. Make sure you ask the condition of the rubber if you are buying used ones. A temporary solution is to wrap the damaged connectors with pipe repair tape available at hardware/home improvement stores. I hope this is helpful, Tony (Happy owner of a'76 KZ750B1 and a'78 KZ750B3).
