quick question, yoke stem kz750 h3
- pugeyed
26 May 2011 15:20
should the bottom yoke stem sit flush with the top yoke when done up tight?
thanks
Mark.
thanks
Mark.
kz750 h3 1982 4cl
- btchalice
Re: quick question, yoke stem kz750 h3
27 May 2011 00:54
pics? so we can see what you mean?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- wireman
27 May 2011 02:17
usually sits just a little below to keep tension on bolt
- pugeyed
27 May 2011 02:37
wish i had pics but haven't unfortunately,
cheers for the info wireman, ive gotta get a custom stem made up and just wanted to know how far it sits in the top yoke.
ill give it 3-4mm clearance so it pulls on the bolt
kz750 h3 1982 4cl
- wireman
27 May 2011 02:42
id go closer to 1-2mm to make sure it sits up far enough to support the tree
The following user(s) said Thank You: pugeyed
- pugeyed
27 May 2011 02:43 - 27 May 2011 02:43
ok thanks
kz750 h3 1982 4cl
Last edit: 27 May 2011 02:43 by pugeyed.
