front brake master cylinder
- dynastydudge
25 May 2011 20:48
anybody have any good ideas about a new master cylinder. the bike is a 1980 kz750 ltd h1. i changed the handlebars to some small ape hangers that are flat at the top, dont need the master cylinder to be slanted like the original. i took one brake disc off the front hub, so it just need to have the pressure for one caliper. and a small sleek mastercylinder would be nice, and if it just plugged in to my wiring would be cool too. i know this is alot to ask, but thought maybe someone on here had done it.
were not here for a long time, just a good time......1980 kz750 ltd h1
1982 honda cm 450e
1982 honda cm 450e
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: front brake master cylinder
26 May 2011 01:22
There are some pretty decent aftermarket ones out there, I'm using one like this one now for 4 years and no problems, smooth response, no leaks and impressive force.
Should give you a level reservoir if the bars are truly flat. Always ask the seller if the photo IS the like the one you'll get though to be sure.
Now is the time to change your brake lines and pads too. Do that and if you squeeze it hard enough when clipping along you will change your underwear! No more pray it stops...
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
