05 636 forks on a 81 KZ1000 LTD
  • jydog
  • jydog's Avatar Topic Author
25 May 2011 20:24
#453571
My 05 636 forks n triple just came in and i noticed somthing I havent seen here or on the customfighters site. The steering stem on the 636 and the 81 kz1000 are the same length. Instead of pressing the stems out and swaping would it be possible to turn the larger 636 down on a lathe to accept the kz stem bearings? and re-thread the end? Look at the pic and tell me if this has been done before.
81 KZ1000 LTD
Griffin GA
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: 05 636 forks on a 81 KZ1000 LTD
25 May 2011 23:04 - 25 May 2011 23:08
#453602
Although the stems are the same overall length, the distance between upper (blue circles) and lower bearings (red circles) are different. The upper bearing, on the ZX stem, will be about 1/2" lower than the upper bearing on the Kz stem. You can see in the pics that the threaded part of the ZX stem is equal to where the Kz stem upper bearing would be. So really the Zx stem is about 1/2" too short.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 25 May 2011 23:08 by StreetfighterKz.
  • jydog
26 May 2011 08:58
#453678
I see what you are saying but there appears to be enough meat on the zx stem to relocate the upper bearing locations and threads. Im not a machinest but this looks possible to match the kz stem. My concern it weaking the zx stem too much. I dont think im going to be the guinea pig. I think im just going to hack off the zx stem, machine what is left and press in the kz stem like everyone else.
81 KZ1000 LTD
Griffin GA
  • btchalice
  • btchalice's Avatar
26 May 2011 13:42
#453699
cutting the weld on a lathe and pressing out the stem is way faster and easier
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • Manomanymotos
  • Manomanymotos's Avatar
28 May 2011 13:35 - 28 May 2011 13:36
#454006
Go to www.allballsracing.com
They have fork swap bearing kits available for darn near any japanese bike. This would be MUCH easier, MUCH faster, and MUCH safer than taking material off of the 636 stem, and just plain makes more sense..
Any time you think about swapping forks, think about swapping bearing out first.
All you need is:
-The I.D (interior diameter) of the bearing (which is the O.D. of the steering stem)
-And the O.D. (the Interior diameter of the steering neck)
Match top and bottom sizes to the steering neck/steering stem and thats it! that way you can use the bearing seals from your front end as well!
BTW, I am NOT an employee or affiliated in any way to All Balls Bearings... Just spreading useful info to fellow KZ'rs ;)
Last edit: 28 May 2011 13:36 by Manomanymotos.
  • jydog
21 Jun 2011 19:43 - 21 Jun 2011 20:01
#458610
Thanks for the info, I did look at the All Balls solutions and it was not possible with the large difference between the stems.
81 KZ1000 LTD
Griffin GA
Last edit: 21 Jun 2011 20:01 by jydog.
  • jydog
21 Jun 2011 19:43 - 21 Jun 2011 19:56
#458611
I found a great deal on some 03 z1000 upper triples. These are a great match for the 636 triple and forks and make it easy to mount the high bars. I need help with making a sleeve to take up the space between the kz stem and where the z1000 stem was. The Machinest says between $50-100 and me supplying the material. Can this be done another way? Ideas?
(it looks offset because the forks are mounted loose and the weight of the bike makes it sag)
81 KZ1000 LTD
Griffin GA
Last edit: 21 Jun 2011 19:56 by jydog.
