Z1B swingarm play
- luc
Z1B swingarm play
24 May 2011 14:37
How much lateral play (if any) is normal?
If i try to twist the rear wheel there is no play but if i pull or push to 1 side i can feel it moving a bit????
- Kidkawie
- I bleed premix
Re: Z1B swingarm play
24 May 2011 14:42
There shouldn't be any play. Might want to check the bolt and bushings.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- luc
24 May 2011 14:57 - 24 May 2011 15:02
The bolt is tight so must be the bushings.
Should i go with needled bearings or factory type bushings/sleeves?
Last edit: 24 May 2011 15:02 by luc.
- btchalice
24 May 2011 15:10
i would use bearings if theyre available for your model
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Kidkawie
- I bleed premix
24 May 2011 15:13
The bolt will wear too.
I'm still running the original bushings, but I heard the bearings are better from alot of people. I don't think running bearings will de-value the bike at all. Save the original parts though (of course).
1975 Z1 900
2004 KX125
2004 KX125
- dshelly
24 May 2011 17:26
Once you put the bearings in nobody will ever know. Besides it's an upgrade right?
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- kawman66
24 May 2011 21:45 - 24 May 2011 22:21
Obviously the bearings are better since the factory did away with a cheaper Manufacturing part i dont belive anyone would shunt it for swapping to bearings. but there should be no play in the swing arm.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
Last edit: 24 May 2011 22:21 by kawman66.
- wireman
24 May 2011 21:52
im thinking quite a few newer sport bikes come equipped with bushings instead of bearings these days
