03/04 zx6rr swingarm on a kz 900
- benhurmx
22 May 2011 09:08
Hi,
I know the 03/04 zx6rr swingarm is a couple of mm wider than the stock kz 900 one. Can i fit this swingarm by shortening its pivot part and not having to shave the spacers on the frame, in that case i could go back to stock if i want to ? or would i have a problem refitting the swing bearings ? ( i know i need to machine a spacer to fit the kz axle, my issue is i prefer not to widen the frame ).
Is fitting a zrx 1200 have the same issues ?
Thanks
Thanks
- andy9802gt
- If it tastes that good, eat it yourself.
Re: 03/04 zx6rr swingarm on a kz 900
22 May 2011 09:34
Look in the filebase OMR has a write up on that swap.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- benhurmx
22 May 2011 09:48andy9802gt wrote: Look in the filebase OMR has a write up on that swap.
I did. He had to widen the frame a bit.
- ultimate fighter
22 May 2011 10:42
it might help to show us some pictures of the areas in question.
love building motorcycles one headache at a time
