My rear brake pedal wont come back up, '80 KZ 750H
  • 876KZ1000A
  • 876KZ1000A's Avatar Topic Author
  • Did you bleed when you built that?
21 May 2011 12:17
#452565
I had my KZ 750 sitting outside under a tarp for a 10 days in the rain. Last Saturday I rented a storage unit and stored the bike until yesterday when the rain finally let up. I rode it to work yesterday and noticed that the rear brake pedal didnt want to go down. I forced it down at a stop light and it didnt return. I was able to pull it up with my toe and ride to the shop using just the front brake. I checked it out and the return spring looks 31 years old but its intact, the pedal is really stiff but it doesnt feel like the master cylinder is resisting.
Some one told me I should buy a bunch of horses once. I bought a bunch of bikes instead.
1974 CB360T frame only, future cafe project
1975 CB360T from dealer collection, rider
1977 KZ1000A frame #2540, full resto under way
1979 CB650 stock/modified, this thing keep evolving
1980 KZ750H LTD, rider
  • peter1958
  • peter1958's Avatar
Re: My rear brake pedal wont come back up, '80 KZ 750H
21 May 2011 13:34
#452570
Take the brake pedal off clean out the rust and lube it up.
  • gengomerpyle
  • gengomerpyle's Avatar
21 May 2011 18:31
#452608
peter1958 wrote: Take the brake pedal off clean out the rust and lube it up.
what he said
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • MFolks
  • MFolks's Avatar
21 May 2011 19:00
#452612
Take off the reservoir cap, and if possible look for two(2) small holes in the bottom, they may be clogged affecting the brake action. You'll probably need to drain and refill the brake system & bleed out the trapped air.
  • Linsk
  • Linsk's Avatar
  • Ron L
21 May 2011 22:09
#452654
[Ditto lube="peter1958" post=452570]Take the brake pedal off clean out the rust and lube it up.[/quote]
1980 KZ 1000 A4 1075 kit 1980 KZ 1000 st 2400 orig miles 1982 GS 1100 E sold 2017 ZX 14R
  • 876KZ1000A
22 May 2011 10:13 - 24 May 2011 10:10
#452733
I spent about two hours yesterday pulling it off and cleaning it up. I had to take the torch to the aluminum mount to get it loose. I went thru the entire rear brake system and it all checks out. The area under the MC boot was a little rusty so I cleaned it out and rubbed silicone lube all over that area and on the groove for the boot. The boot is still in good shape too.
Last edit: 24 May 2011 10:10 by 876KZ1000A. Reason: spelling
  • apbling
  • apbling's Avatar
22 May 2011 10:24
#452734
Same problem on same bike. The pivot point where the pedal and mount meet was frozen up. Hammer and punch finally got it out. Used sandpaper to clean the rust up and then lubed it up. 3 years running and no issues.
  • 876KZ1000A
24 May 2011 10:16
#453235
apbling wrote: Same problem on same bike. The pivot point where the pedal and mount meet was frozen up. Hammer and punch finally got it out. Used sandpaper to clean the rust up and then lubed it up. 3 years running and no issues.
Apbling, it seems weve both had a the same issues with these bikes. My latest thing is the #1 carb is leaking. I thought it was the float bowl gasket originally but there is a trail of varnish down the side, it looks like the fuel crossover is leaking. I have the kits coming to rebuild all 4.
  • apbling
  • apbling's Avatar
24 May 2011 13:35 - 24 May 2011 13:38
#453270
Usual suspects. If you look at alot of my previous posts, I battled the carbs for an entire summer with little leaks and stuff. After you get stuff cleared up, it purrs like a kitten.
If it's the crossover (which mine was leaking too haha, along with the oring), I think I ordered those o rings special from kawasaki through z1. I didn't want to dick with unganging the carbs more than once. Not sure if the regular rebuild kits come with one... I'm guessing they dont.
Last edit: 24 May 2011 13:38 by apbling.
