78 KZ1000 LTD
- mopguy
78 KZ1000 LTD
17 May 2011 21:05
I am having trouble removing the inside bolt that holds the rear brake,the outside one I used a 14mm wrench and it came out with no problem. However the inside one is so close to the bleeder that there is no space to put either a socket or wrench.Does any body know what tool to use there? Tony in Toronto.
- wireman
Re: 78 KZ1000 LTD
17 May 2011 21:50
should be allen head bolts that hold the 2 halves of a 78 rear caliper together,unless you have a 77 caliper on rear im pretty sure anyway.
got a picture,does it look like one of your front calipers bolted to a differant style bracket?
- z1kzonly
Re: 78 KZ1000 LTD
17 May 2011 21:51
Hi Tony, I got your paypal! Thanks! I did have the resevoir cover also.
I will ship them Wednesday to you.
On the back caliper, Take it off with the whole wheel, Pull the axle out. Are you sure it is not an Allen head bolt?
If it is a different style, hex head. An open end wrench on the outside. And a 14mm socket from the backside.
Pictures always help too!
- mopguy
Re: 78 KZ1000 LTD
18 May 2011 12:36
We will try. Thanks.
