rear shock angles
  • wireman
  • wireman's Avatar
Re: rear shock angles
11 May 2011 23:35
#450425
mjg15 wrote: This on my 550, the original location was where the "O' is drawn. The shock angle changed about 10 degrees. I hope it improves the geometry, but I admit that I did mostly for cosmetics. To my eye piggyback shocks look better at an angle greater than stock.
thats nice work! B) B) B) B) B)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
12 May 2011 11:58
#450485
sander,
here are some sanctuary laydown shock mounts prior to welding.
i like the way they extend all the way through the tube to help bridge the two sides and tie them together.
  • dutchz
  • dutchz's Avatar
12 May 2011 13:59
#450500
Thanks Leon, that's pretty much how I will be doing mine. The small ends must fit into their alignment jig and get cut off when the mounts are welded in. I will post some pictures once I have mine turned on the lathe.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • 531blackbanshee
  • Vendor
  • Vendor
12 May 2011 15:55
#450508
sander,
pics are a must :evil: .
  • mjg15
  • mjg15's Avatar
13 May 2011 00:35 - 13 May 2011 23:03
#450606
Make a couple extra sets while you are set-up!! I may be interested in a set or two. On my 550 frame pictured above, we just turned the stock mounts down in the lathe til the old weld was gone. I cut off the threaded end, and then drilled them to use an allen and aluminum cap like a Zephyr.
I forgot what the actual angle measurments are, but these a about 10 degrees different than stock:
Before welding:
After paint:
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Last edit: 13 May 2011 23:03 by mjg15.
  • Hollywoodmx
  • Hollywoodmx's Avatar
23 Mar 2013 13:38 - 24 Mar 2013 15:30
#578322
531blackbanshee wrote:
they use this jig to make sure they are in the right place.
beyond that i am of no help. :whistle:
That is just bad ass!!!!
531blackbanshee wrote: sander,
I don't quite understand this? EDIT. I get it it was what you had in your first pic, never mind.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 24 Mar 2013 15:30 by Hollywoodmx.
