Swingarm Needle Bearing Kit?
- s3steve
09 May 2011 15:49
I bought one of these kits...
And I'm just wonder which way do the washers go?
The only instructions that came with it are in German and there's no diagram.
One set of washers are solid and the other seems to have a washer that is free to spin inside the other.
Do the solid ones go on the swingarm side or the frame side?
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
1975 Kawasaki S3
2006 BMW R1200RT
- Nebr_Rex
Re: Swingarm Needle Bearing Kit?
10 May 2011 00:47 - 10 May 2011 00:51
Would you like the bolt to move or your swing arm?
:whistle:
:whistle:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 10 May 2011 00:51 by Nebr_Rex.
- s3steve
10 May 2011 09:21
So obviously you have less of a clue then me!:silly:
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
1975 Kawasaki S3
2006 BMW R1200RT
- wireman
10 May 2011 09:32
it looks to me from your picture that the bigger washer gets installed against the swingarm,according to the recess on it anyway.
then the smaller washer goes against the sleeve welded into frame for pivot bolt,again judging by size of recess.
judge a semi educated guess anyway. :laugh:
- dshelly
10 May 2011 10:03
The older style swingarms with the bronze bushings are narrower than the ones with bearings. The flat washers are to make up the difference in length. They go on first and then the endcaps.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- s3steve
10 May 2011 10:04
Thanks for your reply wireman.
I was just looking for a quick answer from someone who has used this set before. The plain washer fits inside the recess of larger ones.
I'll translate the German instruction and try fitting the set once I paint the swingarm.
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
1975 Kawasaki S3
2006 BMW R1200RT
- s3steve
10 May 2011 10:06 - 10 May 2011 10:07
Thanks dshelly!
Just the answer I was looking for!
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
1975 Kawasaki S3
2006 BMW R1200RT
Last edit: 10 May 2011 10:07 by s3steve.
