axel removal
  • krayzrider
  • krayzrider's Avatar Topic Author
axel removal
09 May 2011 13:16
#449845
I have a 77 kz1000 with an 18' rear wheel and just picked up a 16' wheel. I recently swapped the swing arm and shocks, etc and now want to put on the 16' wheel. I cant for the life of me remove the axel! I have a new sprocket as well and no prob removing the old one I just cant slide the axel out! What am I missing? It's driving me nuts!
  • wireman
  • wireman's Avatar
Re: axel removal
09 May 2011 13:50
#449849
have you tried spinning the axle with a wrench before removing it? B)
  • krayzrider
Re: axel removal
09 May 2011 13:58 - 09 May 2011 14:06
#449851
Ive tried everything but dynamite! Hammers, wrenches and a little heat too. Not too hot though as I dont want to melt grease seal.I have a manual for 1978 and newer and still dont see what my problem is. Shouldnt it slide right out of the bearings?
Last edit: 09 May 2011 14:06 by krayzrider. Reason: added remark/ question
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: axel removal
09 May 2011 15:42
#449865
it should slide right out.
being as how it doesn't means that it is probably gaulded to a race or spacer.
either is bad.
if it was mine,
i would see if i could unbolt that little block that the adjusters push against on the back of the axle slot in the swingarm and slide the axle wheel and all out the back.then you can attack it while setting it on something to back up your hammering.
hth,
The following user(s) said Thank You: krayzrider
  • MFolks
  • MFolks's Avatar
Re: axel removal
09 May 2011 16:20
#449872
If you can get the axle out,for the new one, a thin coat of the silver anti-seize before installing it will make this easier next time.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: axel removal
09 May 2011 16:39 - 09 May 2011 16:42
#449876
krayzrider wrote: Ive tried everything but dynamite! Hammers, wrenches and a little heat too. Not too hot though as I dont want to melt grease seal.I have a manual for 1978 and newer and still dont see what my problem is. Shouldnt it slide right out of the bearings?
I would pull the grease seals and snap rings basically anything holding in the bearings and then try heating one bearing and get it loose on the axle and drive the axle and the opposite bearing out in one piece. The bearings are shot anyway so no point in trying to save them.
Don't forget that there are two bearings on the Cush side and the outer spacer to contend with.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 09 May 2011 16:42 by andy9802gt.
  • wireman
  • wireman's Avatar
Re: axel removal
09 May 2011 19:04
#449911
ive got a couple of the 77-78 style rear axles sitting here if you need a new one B)
  • bountyhunter
  • bountyhunter's Avatar
Re: axel removal
09 May 2011 19:44
#449921
On mine you have to make sure and loosen the brake caliper holder nut as well as the axle nut to get the axle out.
  • krayzrider
Re: axel removal
11 May 2011 13:55
#450308
Thanks all! Got it out. Had to take wheel off, spray a little Deep Creep and just an hour later and it tapped right out! Got new bearings and seals on the way and all is good!
Thanks again
