biggest rear tire for kz650 c1
  • slittl26
  • slittl26's Avatar Topic Author
  • 1977 kz650c
07 May 2011 07:18
#449389
can anyone tell me whats the widest tire you can fit on a stock kz650 c1 rim
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: biggest rear tire for kz650 c1
07 May 2011 07:59 - 07 May 2011 07:59
#449391
I bought a KZ650 last year and it had a 150/90 on it. I couldn't believe it as that is the size tire i run on my 1000 with extended swingarm. I think this bike was a 1978. Roy
Last edit: 07 May 2011 07:59 by roy-b-boy-b.
  • RonKZ650
  • RonKZ650's Avatar
07 May 2011 11:54
#449421
The rim is only a 2.15" width. A 120/90-18 does the job pretty good. Any bigger than that isn't going to benefit you at all with the narrow rim.
07 May 2011 11:57
#449422
On the stock rim - 130/90V18. Even that may require a slight mod to the stock chainguard. I ran that size for years on my stock KZ650-C1. The 130 is hard to mount on the stock rim with the rim locks, but they need to be used, and it can be done. I now run a 120/90V18 on the rear and frankly it works just as well as the 130. I believe this is because the 130 is so wide that the profile is deformed when being squeezed onto the narrow stock rim. From now on I'll stick with the 120. Ed
  • roy-b-boy-b
07 May 2011 16:45
#449451
The bike I bought had the mag wheel on it. Sorry, I don't know my 650's that well. (not at all)
  • slittl26
  • 1977 kz650c
08 May 2011 08:02
#449543
thanks for the info guess i will stay with the 120 thats on it
