tarozzi rear sets question.
  • 771000KZ
  • 771000KZ's Avatar Topic Author
05 May 2011 11:29
#449023
Hi guys,
I installed some Tarozzi rear sets on my project, I bought the ones specific to my bike not the universal ones.
Attachment rear.jpg not found
The problem I am having is that when I tighten the peg bolt the lever gets so stiff that I can't actuate the brake or shift and if I loosen it then the peg spins and because they are foldable I end up having them fold down when I am sitting on the bike (pretty dangerous). Has anyone installed these? There must be something I did wrong installing them but I can;t figure it out.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: tarozzi rear sets question.
05 May 2011 12:13
#449029
I have two sets of these and haven't had that problem even when I cranked down on the nut holding the peg on.
I can't really tell by the pic but it looks like you have the left/right brackets reversed. The part number stamped on the bracket should have a "L" or "R" after it to designate the sides.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • 771000KZ
05 May 2011 12:18
#449031
Yes, I think I did now that you say it. I'm try reversing them tonight. Thanks man.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
05 May 2011 16:02
#449062
Also make sure the dowels that set the pedal height are in the holes and not being smashed in between the halves.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • dutchz
  • dutchz's Avatar
05 May 2011 16:12
#449066
What Andy said. The bushing that the pedals and adjusters ride on have a collar with a notch in it that the peg andy is talking about seats in. The pedals will not bind when installed correctly.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • trianglelaguna
  • trianglelaguna's Avatar
06 May 2011 01:02
#449155
i have the same ones and they are super nice...i think the guys got you squared away and when set right they wont spin or fold ......mine chew up my shoes and mark my toe .....oh well
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • calvin17d
  • calvin17d's Avatar
12 Jul 2011 11:30
#462443
I am looking to get a set of these for my Kz900 A4. I see that fastfromthepast has them in black with rubber so as to reduce the damage to our shoes.
My question is.................How does the geometry feel on these with the stock forks and superbike bars. Sitting in stock geometry gives me a feeling of vulnerability with the upright sensation delivered at the pegs. I wonder if this will help to alleviate that?
1976 Kz900 A4
  • andy9802gt
12 Jul 2011 20:05
#462523
Calvin I have drag bars on my bike and the tarozzis give me a little more aggressive seating position. I find them to be really comfortable and as has been said elsewhere feedback from the rear wheel is much improved.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • trianglelaguna
12 Jul 2011 22:05
#462547
i had to mess with mine some it is kinda the same as going too tight on the throttle switch housing on some bikes makes the thing not turn....once it is set right it works for me though....i had to order a new part where the linkage threads into the mini shift aluminum spline and 10 mm type nut for the shift shaft....it broke where the aircraft coupler threads male...fast from the past...i think is the link someone here gave me and i bought two of the little boogers for 20 something and ......HERE...i noticed that that same area that if set up wrong cant spin and lever the aluminum female on the foot bolt....grease...i guess in all the cleaning of the bike i had let that steel to aluminum journal seize some and it was sure sweet shifting when i had bearing grease on the inner faces and shaft after re-doing and going for a ride...i guess a shot of dry slide after a ride or lube
1976 KZ900
2003 ZX12R
2007 FZ1000
  • andy9802gt
13 Jul 2011 13:32
#462645
I put anti sieze on mine, just a little bit though to keep the aluminum from galling up. Shifts and brakes like butter.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • trianglelaguna
13 Jul 2011 19:22
#462698
i never even checked em...just put em on....they had been sitting n.o.s for about 10 yrs in bags and come in pieces un lubed if i rember right...wonder how many get installed dry...mine did...ooops...i am gonna silicone spray a teeny shot around the bike on rotating stuff just for kicks...there was grease still in areas of the contact journal but it had worn clean and was rubbing in others
1976 KZ900
2003 ZX12R
2007 FZ1000
