Front and Rear Sprockets
  • kzrebuilder2010
  • kzrebuilder2010's Avatar Topic Author
03 May 2011 14:03
#448560
I have been looking at changing the front and rear sprocket for a lil bit more acceleration is a 14t or 15t with a 33t or 34t too big for a 1980 kz750e I don't know if the 15t will fit the front with clearance
  • steell
  • steell's Avatar
Re: Front and Rear Sprockets
03 May 2011 22:44
#448656
I'm reasonably certain that a 15 tooth 630 sprocket won't fit your 750.
I think you'd be ahead by converting to 530 chain and sprockets, 16/38 maybe
04 May 2011 00:18
#448695
kzrebuilder2010 wrote: I have been looking at changing the front and rear sprocket for a lil bit more acceleration is a 14t or 15t with a 33t or 34t too big for a 1980 kz750e I don't know if the 15t will fit the front with clearance
For faster acceleration, would consider a smaller counter-shaft (front) sprocket, not larger.
Good Fortune! :)
  • martin_csr
  • martin_csr's Avatar
Re: -
04 May 2011 08:54 - 13 Feb 2013 13:25
#448761
Last edit: 13 Feb 2013 13:25 by martin_csr.
