KZ900 with too-small front axle
  • wireman
  • wireman's Avatar
Re: KZ900 with too-small front axle
02 May 2011 23:59
#448451
those look like wheels of some sort of j-bike from the rotors,can you get a closer shot of rotors? B)
  • bangshift440rt
  • bangshift440rt's Avatar Topic Author
03 May 2011 00:00
#448452
That was a cell phone pic from earlier today, i'll take more pictures with that tomorrow. thanks for the help.
  • wireman
  • wireman's Avatar
03 May 2011 00:00
#448453
check your pm box B)
  • wireman
  • wireman's Avatar
03 May 2011 00:10
#448457
Attachment user_16419_kz750_front.jpg not found
do the rotors look like this style?
  • otakar
  • otakar's Avatar
03 May 2011 07:36 - 03 May 2011 07:44
#448495
That is a late model wheel that has a hubless disc. That would be from a 1000 MKII or a GPZ1100. Almost all 1979 and later bikes had those wheels. Since the 76 KZ900 had a rear drum brake, I was wondering how you plan on adapting the rear disc to your bike. This will require some welding on your frame and swing arm.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 03 May 2011 07:44 by otakar.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
03 May 2011 10:55
#448532
Those six bolt rorors bring good money on eBay.
Do you have the calipers too?
I have a front mag that would work. I have a rear wheel but it had the smaller axle.
You need to find a rear drum mag to make it a easy swap over.
I have a friend that has a set of Lester mags for a Z1 KZ drum type set up.
  • otakar
  • otakar's Avatar
03 May 2011 12:14 - 03 May 2011 12:27
#448541
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationA rear wheel from a 650 or a 550 should be a drum I believe? But they will be 16" wheels in most cases.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 03 May 2011 12:27 by otakar.
  • bangshift440rt
03 May 2011 19:28
#448624
Alright folks, I looked closer and it is seven bolts on the rotors. I just imagined even numbers and thought six or eight without paying enough attention. I have some cell phone pics now.
  • wireman
  • wireman's Avatar
03 May 2011 19:31
#448626
those are off a newer j-series bike like that 750 up above B)
  • bangshift440rt
03 May 2011 21:54
#448643
So ahhhh, Who needs a set of J wheels? :blush: Any takers? I'm not going to use them. I also have a complete front and rear disc brake setup for a 1980 or 1981 ltd 750 I need to part with. I actually have the entire LTD but the rest of it is pretty much spoken for.
