OK to use O-ring chain on a KZ250?
  • scott s
  • scott s's Avatar Topic Author
24 Apr 2011 09:16
#446671
Is it OK to use an O-ring chain on my 1980 KZ250?
It fits and clears just fine, but an O-ring chain fits my CB500, too, and they're known to chew up the cases on SOHC Hondas.
I checked my service manual and it didn't say anything one way or the other.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: OK to use O-ring chain on a KZ250?
24 Apr 2011 09:38
#446681
o-ring chain will be fine.if your cases are getting chewed up(on anything)you have a clearance problem that needs addressed.o-ring or non o-ring should not matter as long as everthing has clearance.
hth,leon
  • scott s
24 Apr 2011 10:17
#446689
Thanks, Leon.
The SOHC Hondas have clearance issues on the case with an O-ring chain. Chews right through the case in front of the sprocket on 500's, 750's and maybe a couple of others.
Just wanted to make sure I didn't make the same mistake on the little KZ.
