Rake
- cuskaw74
Rake
23 Apr 2011 19:42
Have any of you raked your frames at all, and if so, how did you go about it?
74 z1900 (in progress again)
74 z1900 (parts Bike)
75 Moto Guzzi v1000 convert
Asheville, NC
www.rockstarmarble.com
Asheville, NC
- Kraz1
- racer54
Re: Rake
23 Apr 2011 20:04
That's fine for you but I'm in Illinois...:whistle:
- Kraz1
Re: Rake
23 Apr 2011 20:49Put that Frame on a Greyhound Bus down to Richmond.racer54 wrote: That's fine for you but I'm in Illinois...:whistle:
- wireman
Re: Rake
23 Apr 2011 21:02
:woohoo:
- kawman66
Re: Rake
23 Apr 2011 23:44Attachment Picture481.jpg not found
I raked mine, I tokk and cut all three upper tubes loose from the neck then i cut the desired amount out of the back bone tube (i took 5/8 inch out) then i heated the two lower tubes to a cherrie red, then pulled the neck back to the back bone tube squared it back up and welded it in then gusseted the frame
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
