Vibration above 3700 rpm
- Topper
20 Apr 2011 19:02
I've only had this '79 KZ750 a couple months and am still getting to know it and working through issues as I find them.
I'm getting a lot of vibration above 3700 rpm. Especially in the handle bars and the mirrors are shaking so much at that point that everything I see is a blur.
I'm a new rider and admit I really don't know what's normal vibration for a 32 year old bike at that rpm.
If I wanted to reduce this where would I start?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- MFolks
Re: Vibration above 3700 rpm
20 Apr 2011 19:53
Is this with the bike on the center or side stand? Is it the same when on the road when riding?
All motorcycles have hamonic vibrations affecting mirrors and instruments. Some bikes have been reported that the left rear foot peg puts passengers feet to sleep when out for a ride.
I'd say get the tools out and check engine mounting bolts for correct torque first, then replace if possible the many and various rubber bits for the side covers & other rubber items.
Ozone and sunlight will dry out the rubber pieces like tires,brake lines and the instrument vibration dampners.
- Topper
20 Apr 2011 20:00
I've mostly only noticed it when riding. I thought it might be wind catching the mirrors and windshield, but it happens at any speed if I get up above 3700 rpm.
I'll try it on the stand and see what happens.
Are there any dampers in the handlebar area or triple tree?
1979 KZ750 Twin
1979 KZ750 Twin
- Nebr_Rex
20 Apr 2011 23:40
They all do that.
My ZRX has a litle vibration a 4K and then goes away.
Try gell grips or you can fill the handle bars with silicone and BB's.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- trianglelaguna
20 Apr 2011 23:43
wrench inside tire?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- TeK9iNe
- What did you do!?!
21 Apr 2011 00:09
Have you performed a proper vacuum balancing of the cylinders?
Makes a big difference when using small throttle inputs (cruising), at any rpm.
Make sure your wheels, rubber, bearings, brakes are all in tip top shape and not wearing/rubbing funny.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Treewizard
24 Apr 2011 00:13trianglelaguna wrote: wrench inside tire?
:huh: :laugh: :laugh:
as tek said, sync carbs they prolly need it anywhy!
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
2002 ZRX 1200R
Raleigh NC
- Topper
24 Apr 2011 09:42
I am probably due for a proper carb sync but it didn't occur to me that would cause this kind of vibration.
I've got a buddy with a manometer. What else do I need to perform a carb sync?
The manual says I need a special carb sync tool. Can it be done without one?
1979 KZ750 Twin
1979 KZ750 Twin
- Motor Head
24 Apr 2011 11:40
A Manometer is the "Special" Tool. Borrow his, if you can. And check the sync/ balance. Part of every tune-up really. You won't know if they are out, or by how much till you check.
- Topper
24 Apr 2011 12:40
No the manual refers to a different carb adjustment tool. Motion Pro makes an aftermarket one:
www.amazon.com/Motion-Pro-CARB-ADJUSTING...tech-data/B000GTVOGY
That's the one I'm wondering about. How much easier does this make the job and is it worth the $20 for someone like me with just one bike?
1979 KZ750 Twin
1979 KZ750 Twin
24 Apr 2011 13:39
Am a little doubtful about sync having much responsibility for vibration oncoming at 3700 rpm and above.
Would concentrate on other possible remedies such as tightening motor mount bolts, etc.
- Treewizard
25 Apr 2011 11:48
i just used a small yet long flat screw driver and a tiny open ended wrench to loosen and tighten the lock nut
will the tool ake it a lttle easier? probly
do u neeeed to has it? nope
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
2002 ZRX 1200R
Raleigh NC
