swapping front wheel
- cary
02 May 2006 17:32
I have an 82 CSR 1000 with rusted out spoked wheels, and want to switch this over to mag wheels, I've noticed a spacer between the brake rotor and the wheel. Will IO have to get a mag with this same spacer, or can I take the spacer and disc assembly off of mine?
- steell
Re: swapping front wheel
02 May 2006 22:54
If you get a mag wheel off an 81-82 KZ1000 LTD it ought to be a bolt on. I have not tried it myself though.
- cary
03 May 2006 14:08
well, looks like I'll be trying an '84 kz700 wheel, we'll see if it's gonna fit, otherwise, ebay time.
- steell
03 May 2006 14:12
To start, you could check the wheel bearimgs list in the FileBase and see if both models are listed there, if not then check buykawasaki.com for the wheel bearing sizes for both models. That will tell you if the axles are the same diameter. As far as wheel width and spacers, you are on your own
- Shoe48
- Live each day as it is your last
03 May 2006 17:44
I might be doing the same thing .as I just bought a 81 CSR 100 Yesterday . I have a 82 750 LTD wheel to try though it looks to be the same even axle size ,, Did you ever get your 1100 up and running ? I will tell you I tried to buy the CSR1000 you bought but you beat me to it ,, I was only 60 miles away ///
Shoeman
Post edited by: Shoe48, at: 2006/05/03 20:44
Post edited by: Shoe48, at: 2006/05/03 20:45
