Brake pad question 81 - up with triple disc brakes
- cyclhed
19 Apr 2011 12:35
I have a 82 KZ1000 CSR. The factory parts catalog shows different brake pad part numbers for the front and rear. Front: 43082-1007. Rear: 43082-1025. These pads also fit a number of different models. The pads are physically the same size and are inter-changeable front to rear. The calipers are the same front and rear. When you buy after market pads both front and rear are the same part number. Does anybody know what the difference is in the factory pads?
I assume it is the compound of the friction material.
The reason I'm asking is that I installed some after market sintered bronze pads ( store.sixity.com/Items/004000361?sck=129...s%20Sintered%20F%2bR )that are all the same front and rear.
The rear brake seems to be getting quite hot after a spirited ride down hill through the twisties. It even turned a bit dark. Before you ask: the whole rear system is completely re-freshed with caliber kit, master kit, braided hose and adjusted properly as per the factory service manual. The pivot points are clean and greased and the calipers were assembled with Sylglide on the back of the pads and the slider shafts. I even installed new rubber bushings on the shafts.
I'm thinking of trying a set of factory rear pads, or maybe EBC pads. BTW the brakes stop perfectly fine and the fronts aren't getting as hot or bluing like the rear one. Maybe its just normal. Anybody seen this? Thanks!
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- testarossa
Re: Brake pad question 81 - up with triple disc brakes
19 Apr 2011 13:57
Is it possible that you could be resting your foot on the rear brake pedal? It sounds like your rear brake is dragging ever so slightly, but with all new parts it would seem that the caliper "should" be functioning correctly. Can you get the rear wheel off the ground to see if the brakes drag at all?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
19 Apr 2011 20:24
Might help to increase gap between rear brake push rod and m/c piston.
Especially where rear brake seems to function okay when cold, but then begins heating enough to cause dragging, which may ultimately progress to lock-up with a blazing hot disc.
