X-ring chain w/clip masterlink trouble
  • Proxy
  • Proxy's Avatar Topic Author
  • 80% Human 20% Nuts/Bolts
18 Apr 2011 13:34
#445331
I once had some trouble with a plain o-ring chain but this is ridiculous. I know it says do not use vice grips when squashing the link to slip the clip on but MAN! Is there a trick? I even tried vice grips but it does not want to compress the link enough. It even says to make sure to move the link plate back against the clip after. I don't see how that is a problem because I don't see how it wouldn't snap back in the first place. I know there is supposedly a tool to do this but is there another trick someone would like to share?
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: X-ring chain w/clip masterlink trouble
18 Apr 2011 16:50 - 18 Apr 2011 16:51
#445354
I know how u feel . it’s a pain.
i use 2 small 3” C lamps and 2 small 1/4" drive sockets. Pick sockets that just fit over the pin, like 1.8” or 3/16” maybe. Then u can put the plate on and compress the 2 pins . now try to remove 1 clamp/socket and get the clip started, the remove the other clamp and finish. It is an awkward thing to do.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 18 Apr 2011 16:51 by mark1122.
  • Proxy
18 Apr 2011 17:43
#445367
I found a site that said to take a 4inch c clamp and a pipe flareing tool and turn off the pads. Then put the flare pad on the c clamp and flare the rivets. It worked like a charm, Better than 80-100 smackers for a special tool. I still had to squish the plates together but the rivet is longer and it was not that hard. So now I have a continuous chain. But I do have a couple of sore knuckles from trying to get that c-clip on.
  • Proxy
18 Apr 2011 18:54 - 18 Apr 2011 18:55
#445378
Here is the link to making the chain riveting tool It works very well. LINK
Last edit: 18 Apr 2011 18:55 by Proxy.
