kz1100-l1 outside diameter of forks with headlight
  • pctech101
  • pctech101's Avatar Topic Author
18 Apr 2011 04:28
#445271
I have been searchin online all day trying to determine what kind of bracket I need so I can mount me some 3in driving lights on the forks. I believe the items are original (headlight mount and turn signals.)
Driving lights have close to a 3/8" mounting bolts.
You can see lights here
m.ebay.com/Member/G/ViewItemPic.aspx?aid...770836196012&emvcc=0
Mounting bolt protrudes from the lights. I find it hard getting info on my bike sometimes
  • martin_csr
  • martin_csr's Avatar
Re: -
18 Apr 2011 11:41 - 13 Feb 2013 11:28
#445313
Last edit: 13 Feb 2013 11:28 by martin_csr.
  • pctech101
Re: kz1100-l1 outside diameter of forks with headlight
18 Apr 2011 12:56
#445326
I have found the charts already. I do not find the diameter for th.e kz1100-l1. I do not want to guess on size and order wrong clamps. Anyone that has a kz1100-l1 and knows for sure what size clamp I would need to mount on tubes. I read 38mm and 41mm. I don't want the actual diameter, I want to know what size is going to fit. Tubes have stock headlight bracket. Please provide size needed.
Thanks
  • martin_csr
Re: -
18 Apr 2011 13:15 - 13 Feb 2013 11:29
#445328
Last edit: 13 Feb 2013 11:29 by martin_csr.
  • pctech101
18 Apr 2011 13:21
#445329
From everything I have seen, there is only one kz1100-L1 and its from 83
  • pctech101
18 Apr 2011 20:48
#445387
Let me make sure I understood correctly. I just by a clamp for my tube size and it will fit around tube and headlight bracket with no problem? If correct, i'd love more opinions. Thanks
