changing fork seals
  • cbhawk
  • cbhawk's Avatar Topic Author
changing fork seals
12 Apr 2011 00:12
#444203
I am changing the fork seals on 82 kz 750 any suggestions i have never done it
  • wireman
  • wireman's Avatar
Re: changing fork seals
12 Apr 2011 00:17
#444206
if they have air caps remove air first ,use an air ratchet to loosen the allen bolt on bottem before removing caps/springs.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
12 Apr 2011 05:42
#444225
Have a genuine shop manual (or a reasonable facsimile) handy.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • martin_csr
  • martin_csr's Avatar
Re: -
12 Apr 2011 11:35 - 12 Feb 2013 12:51
#444243
Last edit: 12 Feb 2013 12:51 by martin_csr.
  • wireman
  • wireman's Avatar
12 Apr 2011 16:08
#444283
if you use an air ratchet/impact you normally can remove it without holding the dampner inside fork B)
