Passeneger foot peg damper
- apbling
10 Apr 2011 11:53
I have a 1980 750-4 LTD that the left rear passenger footpeg vibrates to the point where your left foot goes numb very quickly. I've checked the part diagrams and even my 82 550 LTD and none of them have dampers on it. I can't find the vibration at all either. SO, I was wondering if anyone has any advice on making some dampers.
Thanks.
Thanks.
- TeK9iNe
- What did you do!?!
Re: Passeneger foot peg damper
10 Apr 2011 13:20
You ride with your feet on the passanger pegs!? :laugh: Just kidding.
Where ever the pegs mount to frame/mount/etc, and anything in between that is a bolt, could use a nice homemade rubber washer or two cut from some cheap sheet rubber you can buy all over the place.
Mix up rubber washers between metal ones, and longer bolts, helps alot.
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- apbling
10 Apr 2011 14:31
Ok, but should I try to "wrap" the bolt? The driver footpegs have a damper that wraps the entire bolt and fits snugly into the footpeg mount. I don't think I could make them work in the passenger ones, but maybe I could fab something similar...
www.z1enterprises.com/detail.aspx?ID=1942
and yeah, sometimes when you really give her a fistful and the front end comes up, you have to stand on the passenger pegs...
10 Apr 2011 14:32apbling wrote: I have a 1980 750-4 LTD that the left rear passenger footpeg vibrates to the point where your left foot goes numb very quickly. I've checked the part diagrams and even my 82 550 LTD and none of them have dampers on it. I can't find the vibration at all either. SO, I was wondering if anyone has any advice on making some dampers.
Thanks.
- apbling
10 Apr 2011 14:53Good Fortune!
- wireman
10 Apr 2011 16:26
what patton said also check chain/sprockets and swingarm pivot
- apbling
10 Apr 2011 17:38
Chain is lubed and in good shape. It's been tuned up and runs like a top. The vibration is in the left passenger peg and is related to RPM. For example, you can feel the vibration when the bike isn't moving but you rev the motor. So, chain, sprocket and swingarm I think can be ruled out.
I'll try the motor mounts...never thought of that. Seems odd though that it would only be on the left peg if it was the motor mounts.
- wireman
10 Apr 2011 17:47
output shaft is on left side of motor so if motor is shaking it could be transmitted through chain /sprockets.
might also check output sprocket nut to make sure its tight under sprocket cover
