2.5' mini speedo
- 771000KZ
2.5' mini speedo
03 Apr 2011 09:52
Hey guys, i have a 1998 YZF 600 front end on my 77 KZ, I need a speedo and I found this one at dime city:
www.dimecitycycles.com/vintage-cafe-race...edometer-490291.html
How do I find out if it's the correct ratio for the yamaha speedo gear on the wheel?
Re: 2.5' mini speedo
03 Apr 2011 13:50 - 03 Apr 2011 13:51
The advert says -
*The speedometer ratio is 60MPH @ 2240RPM.
Measure the circumference of the front tire you will use then convert measurement to feet. (ie- 63 inches = 5.25 feet).
Divide that number into 5280 to get the rpm.
In this example we have 5280 / 5.25 = 1,005.7. Not even close.
I'm wondering if this speedo operates of the ignition system rather than off a wheel trigger since 2240 rpm at the wheel would necessitate an 8 or 9 inch diameter wheel and tire??
The best way to find out is to contact the seller.
Last edit: 03 Apr 2011 13:51 by TexasKZ.
03 Apr 2011 23:33 - 05 Apr 2011 12:52This post is removed as being in violation of the following Rule.enzyday wrote: фото на футболке... [Solicitation for Tee-Shirt Sales]
PRODUCT OR SERVICE ADVERTISING IS STRICTLY LIMITED
KZrider.com is not a place for you to solicit sales of any kind. No member is allowed to refer to their own business, or any business to which he/she is associated, through the discussion forum or personal messaging system (U2U). There are three exceptions: 1. As permitted in Classifieds (consumer-to-consumer transactions). 2. Each member is allowed a simple link ( somesite.com ) in their signature, which link shall include no description of any kind. 3. Paying advertisers are allowed to post in the Vendor forum.
Meanwhile, click > www.cafepress.com/kzrider.47879996
Last edit: 05 Apr 2011 12:52 by Patton.
05 Apr 2011 12:37 - 05 Apr 2011 12:50
771000KZ -- check your PM's.
Last edit: 05 Apr 2011 12:50 by Patton.
