Rearsets question
  • fordtruck
  • fordtruck's Avatar Topic Author
Rearsets question
01 Apr 2011 02:49
#441867
I've been searching through old posts about rearsets and see that they usually get in the way of the kickstarter. Are there any bolt on rearsets for a 77KZ1000 that don't interfere with the kickstarter?
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • testarossa
  • testarossa's Avatar
Re: Rearsets question
01 Apr 2011 10:03
#441897
I'm no expert, but I do have some fabricated rearsets on my bike. It seems to me that they are all going to interfere with your kicker if they are in any sort of normal rearset postition. Mine take up about half of the original kick start throw, but it's still workable. As long as your bike is not too hard to start, then the kicker can still work. Are you kick only at the moment?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
01 Apr 2011 10:19
#441901
When I was using the flipped stock pegs, I was able to fold the right peg up and it would stay there. Then I could get full stroke out of the kicker.
Just gotta remember to fold it back down before you ride away!
Build Thread
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
01 Apr 2011 15:20
#441956
When I bought my Tarozzi's they told me that the foldable ones will clear a kicker. Ca'nt verify that though as I don't have a kicker.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • fordtruck
02 Apr 2011 02:33
#442112
Testarossa I have electric start, but its iffy. It has cranked over slowly since I bought the bike a few years ago. It has a new battery. I also made a new positive battery cable because the old one was hacked together. Now that I rebuilt the motor with high compression pistons, it's even worse. When the motor is hot it's really hard to get it to turn over. Once in a while I have to resort to kickstarting it. So, I either need to figure out why it turns over so slowly, or keep the kickstarter.
andy9802gt, I emailed Jim at FastfromthePast and he stated that none of the Tarozzi's will work with the kickstarter. I was hoping that the folding set would work. Can anyone confirm if the kickstarter will clear with the folding Tarozzi's?
  • testarossa
02 Apr 2011 02:42
#442113
You need to get in contact with mark1122. He retro-fit a stronger Honda starter to his bike for the very same reason. He's starting a built 1200cc motor with his setup, and I know that he removed his kicker. I'm sure that correcting your starter issue will be cheaper than a set of Tarozzi's that may or may not solve your problem. Not nearly as cool, but much more functional.
2004 ZX-10R
Angola, IN
  • MFolks
  • MFolks's Avatar
02 Apr 2011 02:46
#442114
Don't forget to replace the Negative battery cable too, as it's part of the electrical system. I'm using 4 gauge welding cable as battery cables.
  • kawasakispeedin
  • kawasakispeedin's Avatar
23 Apr 2011 20:13
#446568
were you ever able to figure out a set of rearsets that would work? my electric start works perfect but i love the look on the guys faces when i kick start it in one try! i was wonderring if maybe gpz footpegs/shifter/brake brackets would work? i have a 1980 kz1000 ltd...
-1980 Kz1000 ltd (current)
-1993 Suzuki GSX600F
-2006 ZZR600 (past)
-1981 GPz550 (past)
  • fordtruck
23 Apr 2011 20:18
#446570
No I haven't. I did replace my starter with one out of my neighbor's parts motor. That fixed the slow cranking. I'd still like to keep the kickstarter as a backup. If you find out anything, let me know.
  • mvent
  • mvent's Avatar
26 Apr 2011 22:03
#447264
Is the installation of the Tarozzis straight forward? How is the fit and quality?
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • MFolks
  • MFolks's Avatar
27 Apr 2011 01:39
#447298
Try this man for a good electrical starter: starters
push button start your motorcycle--no matter what compression or cc s.---- if you have a suzuki gs style or---- kawasaki kz style or ---yamaha fj. i can build a super starter for your bike. cashio cycles 8391 hwy 23 belle chasse,la. 70037 1-504-393-2260 shop phone or cell 1-504-458-5237
  • fordtruck
28 Apr 2011 15:25
#447577
MFolks wrote: Try this man for a good electrical starter: starters
Thanks for the info. I fixed mine by swapping in a different starter.
