fork air valves.
  • lobstermobster
  • lobstermobster's Avatar Topic Author
fork air valves.
01 Apr 2011 02:29
#441864
sooooo working in the garage today was trying to get my forks apart from the bike. working alone was a little difficult but I managed. jacked up the front of the bike to pull the whole front end down the trees like we usually do.... but for some reason the forks would only slide out about a inch and a half below the top tree. me being awesome at pretty much everything thought it would be a good idea to use a rubber mallet to hammer the forks down the bottom tree.
so i got all the way down to about half an inch from the bottom tree and i guess i had one bad swing a i hit the air valve cap on the top of the fork. This pretty much knocked the 30 year old piece right off where the threads meet the nut.
This is the part number --> 16126-1003
So my point of posting is, Where can I get one of these? nothing on ebay that i could find searching that part number. and a couple stores i did find that show the part you cant add to cart because it says "PART OBSOLETE" wtf.
oh and its a 81 kz650 if that makes a difference.
1981 kz650 w/ flux capacitor
  • purls
  • purls's Avatar
Re: fork air valves.
01 Apr 2011 02:39
#441865
Hey I got lucky a few days ago with these guys; www.plenternz.com/index.php
1983 KZ750 Spectre
1978 KZ650B2A
  • lobstermobster
01 Apr 2011 03:10
#441870
ya. they dont have them either.
  • wireman
  • wireman's Avatar
01 Apr 2011 03:18 - 01 Apr 2011 03:39
#441871
if you can wait till morning i can call my buddy in ashland to see if he has a frontend with air caps on it B)
better yet heres his phone # 402-944-6111,his name is tim masters 6 cycle(hwy 6)
Last edit: 01 Apr 2011 03:39 by wireman.
  • lobstermobster
01 Apr 2011 03:51
#441874
yeah im not going anywhere. But id like to just get the valve and not a whole frontend.
  • wireman
  • wireman's Avatar
01 Apr 2011 03:54
#441875
he sells parts off of anything,im just saying maybe he has a frontend he can steal one from or maybe has a cap laying in a box he can sell ya B)
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
01 Apr 2011 10:59 - 01 Apr 2011 11:01
#441912
On the Kawasaki site, if you click on the part number, then the yellow question mark "?" it will tell you what other models used this part. Print that out and head to Ebay.
When you work on front ends like that you should slightly pry the clamps loose at the pinch bolts and the fork will basically fall out. Watch your toes. Before you reassemble run a scotch brite pad inside the clamps where the fork tubes go, and spray some WD.
Model (33):
KDX175-A2 (KDX175) (1981)
KDX175-A3 (KDX175) (1982)
KDX250-A1 (KDX250) (1980)
KDX250-B1 (KDX250) (1981)
KDX250-B2 (KDX250) (1982)
KDX400-A1 (KDX400) (1979)
KDX400-A2 (KDX400) (1980)
KDX420-B1 (KDX420) (1981)
KDX450-A1 (KDX450) (1982)
KL250-A3 (KLR250) (1980)
KL250-A4 (KLR250) (1981)
KL250-A5 (KLR250) (1982)
KLX250-A1 (KLX250) (1979)
KLX250-A2 (KLX250) (1980)
KX125-A4 (1978)
KX125-A5 (1979)
KX125-A6 (KX125) (1980)
KX125-A7 (KX125) (1981)
KX250-A4 (1978)
KX250-A5 (1979)
KX250-A6 (KX250) (1980)
KX250-A7 (KX250) (1981)
KX420-A1 (KX420) (1980)
KX420-A2 (KX420) (1981)
KZ1300-A1 (1979)
KZ1300-A2 (1980)
KZ1300-A3 (1981)
KZ1300-B2 (1980)
KZ650-H1 (CSR) (1981)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 01 Apr 2011 11:01 by Kidkawie.
  • wireman
  • wireman's Avatar
01 Apr 2011 12:15
#441930
i just talked to tim at 6 cycle,he said he has a set of bent 750 forks with same fittings .
he said he'll sell you the part for $10 plus shipping,give him a call at the number above if it sounds workable to ya. B)
  • lobstermobster
01 Apr 2011 17:10
#441980
@kidkawie: yeah I actually thought of that this morning while still pissed about breaking it last night. I dont know why I didnt think of it then, I had to do that to get my shifter lever off. And i actually did find somewhere that had the same part for a kawi dirt bike but its 20 bucks.
@wireman: that sounds awesome except im at work all day everyday this weekend. it would be awesome if you could throw him my email (Lobstermobster@yahoo.com) and that would be good if he could do that. if not just lemme know and maybe i can hit him up on monday.
  • wireman
  • wireman's Avatar
01 Apr 2011 19:41
#442006
or i can just pick it up tomorrow for ya and mail it to you.
pm me your mailing address B)
  • lobstermobster
01 Apr 2011 22:22
#442051
PM SENT!
  • wireman
  • wireman's Avatar
08 Apr 2011 21:02
#443479
just checking to see if that cap made it to you yet? B)
