KZ axle sliders onto GS1100 swingarm
  • hal0tw0
  • hal0tw0's Avatar Topic Author
28 Mar 2011 07:52 - 28 Mar 2011 07:52
#440913
Sorry, I searchedy...... but I have the GS1100 swingarm minus the pivot bolt and all axle slider hardware. I want to keep my rear kz wheel for now and eventually lace up to a wider wheel. Anyways, can you use the KZ sliders onto the GS axle? They are both the same diameter. Looking for all the pieces is getting pricey so if I can save a few bucks Id like too.
Thanks
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
Last edit: 28 Mar 2011 07:52 by hal0tw0.
  • wireman
  • wireman's Avatar
Re: KZ axle sliders onto GS1100 swingarm
28 Mar 2011 08:50
#440918
stock pivot bolt will work,not sure about axle parts B)
  • otakar
  • otakar's Avatar
28 Mar 2011 22:52
#441121
Yes the chain adjusters work just fine. You however will require a much longer axle. I use one from a KZ1300 and it is perfect.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
The following user(s) said Thank You: hal0tw0
  • hal0tw0
28 Mar 2011 23:54
#441133
perfect. thanks!
