front end
- hmeric7
front end
27 Mar 2011 19:59
yes im wondering what other bikes front ends will bolt on the kz1000 i have a 77. i most likely neeed new calipers and rotors and what not so im debating on just swapping out my front end with one off of another bike and wanted to know if any of em would just bolt on with minor mods.
1977 KZ 1000 LTD
Re: front end
28 Mar 2011 11:48
if swapping the steering stems is a minor mod to you,then yes any front end will bolt on with minor mods.there are some front ends that can just have the stem bearings swapped out and bolt on.although i don't know which ones these are.
i have done several steering stem swaps to install later model(sportbike) frontends on these old kz's.
when searching for a front end to swap try to get it as complete as possible,brakes wheel axle spacers.you will save time and money in the long run.
hth, pm me if i can help you.
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
- Proxy
- 80% Human 20% Nuts/Bolts
Re: front end
28 Mar 2011 13:25
I do know that some will reduce your steering angle or hit the tank. Might just be the USD trees and forks tho. Do the homework because little surprises like that will ruin your day.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
