how to install kz1000 stock swing arm bearings
- ronnie chabot
26 Mar 2011 20:49
hi
have new powder coated stock swing arm for my kz1000
how is best way to install new swing arm bearings.
im going to order from redline cycle.
any help.thanks ronnie
- wireman
Re: how to install kz1000 stock swing arm bearings
27 Mar 2011 14:25
if you have access to a press it would make your life really easy,how did you get the old ones out?
- ronnie chabot
27 Mar 2011 22:01
hi
were out and came with old ones .thay look new but im not useing then ill get some from redline cycle
thank for you help
ronnie
thank for you help
ronnie
- asevans
27 Mar 2011 22:56
if i can remember right i had some pvc pipe laying around that fit the diameter of the bearings and was able to tap mine in. had a shop remove the old ones.
good luck
good luck
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
- kawman66
29 Mar 2011 00:04
last one i did i took to the dealer and let them play with it.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
