rearsets question.
- Lazyman06
rearsets question.
20 Mar 2011 11:28
I've asked this before but still didn't quite understand. when it comes to putting on aftermarket rearsets are there any that bolt right on or how do you make a bracket to make it work. to me a simple plate would bring about durability issues.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- trianglelaguna
Re: rearsets question.
20 Mar 2011 12:32lets ee if this works...i'm struggling with pics again....these Tarrozi rearsets bolt right up and are made in different peg types and mix and match options i believe 225-285 imo.......
(tarrozi)and i think they work great and look really cool,BUT, but they mark up my boots and are grinding a hole in the soles because of there file/rasp like peg texture...i bet the rubber pegged ones are better......
you can make your own GREAT ones by simply
removing the two nuts that hold the foot peg brackets to the frame on each peg assembly
flip the right peg over and reverse the holes so it fits on the left frames peg mount bolts...it will now be higher and rear-set,and upside down...this will mean pulling the pin and clip that hold the rubber peg on the bracket and switching the pegs so they now fold up instead of flop down....then do the same for the other peg...when your done it is almost impossible to see they were messed with by the casual observer....the shifter and brake arms are now way too long(unless you have size 16 boots
by making your own rear sets you can
1.) keep the comfy non grinding pegs you have now
2.) keep the colors and mounts that match the bike
3.)the pegs are now in line with the rear swingarm pivot and the control and feedback of the rear wheel is way better imo
I have just spent a summer with the Tarrozi and have also had the home made ones on my bikes for years...the home made ones are 10 times better imo...and they dont cost 250.00
other guys make there own out of modern bikes rear sets and i'm sure they can provide pics and instructions...i think some of the ones look to off set from the lines of the KZ...the reason imo is that the bikes they were borrowed from had different stances and they rear sets often sit too low and behind the swing arm pivot...like putting a front fender from a crusier on a standard and having it not follow the wheels curve
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
20 Mar 2011 12:40this picture shows a set of rear set pegs using nothing more than what i began with...if you look close you can see how the pegs are now up and back almost right where the rear end is pivoting on the swing arm bolt...these are comfortable and do not chew my shoes up...they are tucked in tight and do not scream hack job...my feet are big enough to reach the controls with my tippy toes and some scrunching up for shifts...i will shorten the brake and shifter one day...
sorry the pic is not a close up it's raining cats and dogs now or i would get a better shot for you...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
20 Mar 2011 13:50here is a closer phone pic of the peg bracket swapped from the other side...flipped upside down,and the peg pin pulled..pegged flipped right side up and pin put back...big up and back difference with little cosmetic change
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- steell
20 Mar 2011 14:54
I did the same peg flip on my 750 twin a couple years ago. Cost me nothing (I already had the shift linkage from a GPz750) except some time.
Looks and works great.
- Lazyman06
20 Mar 2011 16:34
might try swapping the pegs thankfully that was one of the things that didn't get burned up.(still digging out old wires and having to break molex connectors apart to get the wiring harness loose) still gonna be a while on getting this down to a rolling frame
- jimstan
- trianglelaguna
22 Mar 2011 21:09
now those are nice!
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- Mercury Kid
30 Mar 2011 19:21
Fast From The Past still sells the tarozzi kits. At least their website still lists them.
trianglelaguna, any pics of the shifter side? I ran out and flipped my pegs over yesterday after seeing your picture, but my shifter is waaay too far away. What did you do, if anything?
'76 KZ900-Z1 clone
Z1 70's period longbike
- wireman
30 Mar 2011 19:27
craig has size 17 feet! :laugh: try a dirtbike shifter,they tend to be shorter
- hocbj23
30 Mar 2011 20:17
KZ1300 shifters are shorter as well and also are a sort of rearset as they have a short linkage.worked on my kz1000.bj
- mtbspeedfreak
Re: rear sets question.
30 Mar 2011 21:01How do you shine your engine case? That's beautiful!
PMC makes a REALLY nice kit (although they're 500-odd dollars) that comes with a shorter shifter AND brake pedal as well as the shift linkage. I believe they come with rubber footpegs that has a stock looking feel. I'll see if I can root through their site later this evening and I'll hopefully throw a picture up.
2000 ZRX 1100
1976 KZ 900- Daily Driver
