pivot bolt to axle length
  • Stu Pidasole
  • Stu Pidasole's Avatar Topic Author
  • if you aint mod'n, you aint rock'n!
17 Mar 2011 20:39
#438707
whats the stock measurement from the center of swingarm to center of rear axle? thanks Joe.
  • porchev914
  • porchev914's Avatar
Re: pivot bolt to axle length
17 Mar 2011 22:22
#438714
I might need to double check, but mine was 19 5/8" ish.
FRANKEN Z!
18 Mar 2011 02:24
#438732
This dimension of course varies with position of axle in the slots at end of swingarm which allow for adjusting chain slack.
As known, the distance should be equal on both sides from center of pivot bolt to center of axle, regardless of reference marks on the swingarm which might be inaccurate. And at which time the chain should be in perfect alignment approaching and exiting both sprockets.
Good Fortune! :)
