Suspension/Fork mods for 1978 KZ1000 frame
  • 77/78 KZ1000LTD
  • 77/78 KZ1000LTD's Avatar Topic Author
10 Mar 2011 20:36
#436951
I am new to this site and this is my 1st post. I have a 77KZ1000 ltd rigid custom that I plan on putting back into a 78 frame. My back just can't take it anymore and I want to be able to leave my kidney belt at home when I travel more that 50 miles. I have an old SBF rigid frame, HD 35mm front end and run a 150/80 16 rear wheel/tire. I would like to know what are the most current fork,swingarm mods that I can use on the 78 frame to make it handle better and still be able to use the rear tire set up. Thanks for your time!
  • porchev914
  • porchev914's Avatar
Re: Suspension/Fork mods for 1978 KZ1000 frame
10 Mar 2011 21:22
#436965
The easiest road to what you want would be a stock frame, stock front suspension and a GS swingarm.
FRANKEN Z!
  • stonemaster
  • stonemaster's Avatar
11 Mar 2011 04:52
#436986
I got an 82 zuk gs 1100 swingarm on mine and the 150 tire will just fit, I found mine on GSresource parts thread for a 100 bucks, thats a badass bike too bad
  • toad
  • toad's Avatar
11 Mar 2011 07:11
#437020
I have the gs1100 swingarm on my 78 frame, worked great a little tweaking nothing major,just make sure tire is centered.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • stonemaster
11 Mar 2011 07:25
#437027
yea I think I had to add a couple of washers, that was it
11 Mar 2011 08:32
#437032
Even if you simply use the stock frame/swingarm/fork you will find it handles better than your current configuration. Hardtails are not known for good handling characteristics. Ed
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
11 Mar 2011 08:45
#437034
Keep in mind that he is using a 16 inch rim.
You may be able to fit a wider tire in a stock swing arm, with the smaller rim.
If you measure from the center of the wheel to the widest part of the tire, I have a stock swingarm I can measure at that point.
Build Thread
  • wireman
  • wireman's Avatar
11 Mar 2011 10:41
#437060
cool bike,i thought it was a flat tracker at first! :laugh:
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Mar 2011 11:00
#437061
If you still want to keep the style your bike is now you can use a plunger frame. Not a full rear suspension but not a hardtail either.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • 77/78 KZ1000LTD
11 Mar 2011 14:32
#437101
Tell me about it. I have to turn corners like a car but when I straighten out, she runs like a bat out of hell:woohoo: !! My riding buddies think I am crazy to ride this on the interstate.
  • 77/78 KZ1000LTD
11 Mar 2011 14:33
#437102
Yeah ,she was a digger when I first put it together
  • 77/78 KZ1000LTD
11 Mar 2011 14:37
#437104
Thanks man! I did the white walls by hand, ol' school!
