Control levers
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
Control levers
06 Mar 2011 23:35
#435799
Hey guys, what are our options for different levers? (Brake and clutch) I'm grabbing a Superbike bar in a week or two (and shorter throttle cables and brake hoses) as well as a set of Throttlemeisters ( throttlemeister.com/ ). I think a somewhat more modern set of levers would set everything off!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • mtbspeedfreak
Re: Control levers
07 Mar 2011 20:37
#436050
EVERYONE is using the stock levers?
2000 ZRX 1100
Re: Control levers
07 Mar 2011 22:38 - 07 Mar 2011 22:40
#436073
Stu Pidasole wrote:
was thinking about getting a silver pair. my buddy mike baught the black ones for his r6. they look sharp.
cgi.ebay.com/ebaymotors/Kawasaki-ZX6R-CN...&hash=item45f89aab5b
:unsure: Perhaps won't fit KZ900.
Good Fortune! :)
Last edit: 07 Mar 2011 22:40 by Patton.
  • mtbspeedfreak
Re: Control levers
07 Mar 2011 23:20
#436077
Yikes! I didn't email some of the manufacturers of these levers QUITE yet, is this something that isn't done very often, or what?
2000 ZRX 1100
  • testarossa
  • testarossa's Avatar
Re: Control levers
08 Mar 2011 03:36
#436082
I just had a look, and all three of my bikes have the same end on the clutch cable where it attaches to the lever. Seems like any new lever from a cable clutch bike should work. As for the brake side, you would need to switch to a master cylinder from the newer bike to make it work. That's actually not to bad of an option. I'm running a 95 GSXR master cylinder on my KZ1000 and it works fine. Just find something that fits a 7/8" diameter bar with the same size M/C piston and you should be fine. I don't know if anyone makes a replacement KZ brake lever that doesn't look stock.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • djturnz
  • djturnz's Avatar
Re: Control levers
09 Mar 2011 07:01
#436481
Is there a place to find the bore and stroke of my M/C and to cross references which newer units are the same?
1982 KZ750 (4) LTD
  • z1kzonly
  • z1kzonly's Avatar
Re: Control levers
09 Mar 2011 09:27
#436506
I have a set of Magura Power Levers, had them for years.
I'll shoot a pic later.
  • mtbspeedfreak
Re: Control levers
19 Mar 2011 19:59
#439006
z1kz, I'd love to see a pic if you get the chance!
I was rooting through the PMC catalog the other day and came across a pair of levers. They aren't quite as "indented" as modern superbike levers are, but they are not flat like the stock levers are. I think if I got them powdercoated flat black, they'd be looking sharp!
2000 ZRX 1100
