Chain Lube
Re: Chain Lube
05 Mar 2011 10:04 - 05 Mar 2011 10:04
Recalling early ads touting then new O-ring style chains, which claimed no need to lube because internally lubed for life with O-rings keeping the internal lube inside and protecting against road gunge and water intrusion from the outside.
Buying into this meant occasional light oil spray to help prevent unsightly rust on the chain (which actually worked surprisingly well for many miles).
And then the chain lube vendors convinced us that the life-time internal lube did in fact eventually ooze out, thereby necessitating use of chain lube regardless.
Last edit: 05 Mar 2011 10:04 by Patton.
- grumpy56
Re: Chain Lube
05 Mar 2011 10:05
I've had excellent results with Bel-Ray "Clean". Works as BountyHunter describes as well.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- OKC_Kent
Re: Chain Lube
05 Mar 2011 11:26
bountyhunter wrote:
I got 35,000 miles on my x-ring chain using this stuff. About 3 adjustments needed during that whole time.
Took me 30 years to find it: DuPont Multi Purpose Spray Lube (with teflon) in the big blue can at Lowe's for $5. It goes on as a liquid spray to penetrate the links and the carrier dries leaving a waxy coating. It's clear, not sticky and doesn't fly off and make a mess. I've been using it for two years and my new chain hasn't needed adjusting. Works better than the other stuff.
Cashion, OK
78 KZ650 B2 85,000+ miles
- mtbspeedfreak
Re: Chain Lube
05 Mar 2011 11:42
Patton wrote:
Next time you're testing, give flat, semi-flat, matte and glossy a try. Then switch to the high temp grill paint and maybe polish it off with black primer?
Also haven't tried but will likely pass on the black paint.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
Re: Chain Lube
05 Mar 2011 11:48
And before we all start saying the mileage we got with our chains, first specify what chain you're running because that obviously makes a difference. If you're using a generic "eBay special" non-O-ring 530 chain, you'll only get 8,000 miles. I have a really nice ($$$) DID 630 O-Ring chain that I tightened once in 10,000 miles.
2000 ZRX 1100
- bountyhunter
Re: Chain Lube
05 Mar 2011 14:05
TexasKZ wrote:
I would add before I switched to the Dupont multi purpose lube, I tried both kinds of PJ, chain kote, and some other kinds of junk I don't remember. Never got more than 10,000 out of a very expensive chain so I was not a happy camper.
The Dupont Multi Pupose Lube is exactly the same stuff they sell as their chain lube, except it's cheaper when they label it as multi purpose lube (that according to somebody who sells it). Anyway, my new chain is not wearing much at all using it so I think it's good stuff. BTW, the chain is the X ring kind sold by Z1 which appears to be a very good chain for the money.
bountyhunter wrote:Took me 30 years to find it: DuPont Multi Purpose Spray Lube (with teflon) in the big blue can at Lowe's for $5. It goes on as a liquid spray to penetrate the links and the carrier dries leaving a waxy coating. It's clear, not sticky and doesn't fly off and make a mess. I've been using it for two years and my new chain hasn't needed adjusting. Works better than the other stuff.
+1
more than 19,000 miles and counting, chain and sprockets look virtually new, no adjustment needed for last 12,000 or so.
- bountyhunter
Re: Chain Lube
05 Mar 2011 14:07
Patton wrote:
The problem with the Made in China stuff is that an hour later, your chain is hungry again......
- bountyhunter
Re: Chain Lube
05 Mar 2011 14:09 - 05 Mar 2011 14:11
Patton wrote:
What convinced me the "lifetime lube" claim was BS was the fact the chains wore out at 10k miles of easy street riding. Not happy after dropping about $110 for a chain....Recalling early ads touting then new O-ring style chains, which claimed no need to lube because internally lubed for life with O-rings keeping the internal lube inside and protecting against road gunge and water intrusion from the outside.
Last edit: 05 Mar 2011 14:11 by bountyhunter.
Re: Chain Lube
05 Mar 2011 14:10 - 05 Mar 2011 14:14
bountyhunter wrote:
Not a problem for Ron, though.
He'll just ride over there and pick up a few cans.
:laugh: :woohoo: :laugh:...The problem with the Made in China stuff is that an hour later, your chain is hungry again......
Last edit: 05 Mar 2011 14:14 by Patton.
- P21
Re: Chain Lube
12 Mar 2011 17:35
a little update
i cleaned chain real good and swingarm off from the mess before.
this time i used DuPont Multi Purpose Spray Lube (with teflon) in the big blue can.
and i will say iam HOOKED
no fling off saddlebags no mess no mess on wheel where was this stuff 20 years ago
Thanks for all the replies
Kawasaki KZ 1000 Police (2002) P21
- TeK9iNe
- What did you do!?!
Re: Chain Lube
12 Mar 2011 18:39
I use whatever is closest at hand :laugh: no. PJ1 usually.
I have to adjust my chain several times per season - even took a link out already, but its the power in the bike, not the chain being cheap, cuz it wasnt. i wish.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- testarossa
Re: Chain Lube
12 Mar 2011 19:55
bountyhunter wrote:
+1
This is good stuff, and it works for more than just MC chains. Not to mention it's less than half the price of the boutique stuff available at your local shop.
+1
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
