Mounting tabs on fork lowers
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
24 Feb 2011 14:22
#433159
Hey guys, easy question for y'all:
What are the single mounting tabs on the fork lowers on the opposite side of the caliper mounting tabs???
I'm looking into a dual disc conversion and I'd invert the forks to swing the calipers around so they are underneath the lowers.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • MFolks
  • MFolks's Avatar
Re: Mounting tabs on fork lowers
24 Feb 2011 14:50
#433165
I believe they act like the rear brake torque link does. It prevents the caliper from rotating when brakes are applied.
  • mtbspeedfreak
24 Feb 2011 14:56
#433167
Nothing is attached to these mounting tabs. I've seen a few instances where the tabs are actually ground off to make everything cleaner.
2000 ZRX 1100
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
24 Feb 2011 15:09
#433168
reflector mounts maybe? Post a picture so we can see what you're talking about.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • mtbspeedfreak
24 Feb 2011 15:10
#433169
A picture is worth a thousand words.
I'll take a picture and post when I get home from work this evening. Probably get rid of a bunch of confusion :)
2000 ZRX 1100
  • PLUMMEN
  • PLUMMEN's Avatar
24 Feb 2011 15:18
#433172
fender supports for kz650 B)
  • z1kzonly
  • z1kzonly's Avatar
24 Feb 2011 15:21
#433174
Z1R's had them also. Just a factory thing. Different models used them for a fender bracket.
Production parts, multi fit.
I have a set ground off. Then I just looked in my junk pile and seen them on opposite sides.
  • z1kzonly
  • z1kzonly's Avatar
24 Feb 2011 15:30
#433175
Here is a bike outside that has the tabs ground off.
  • z1kzonly
  • z1kzonly's Avatar
24 Feb 2011 15:37
#433178
Here is another bike, check out the countersunk flatheads, and the axle caps.
24 Feb 2011 15:40
#433179
mtbspeedfreak wrote:
...What are the single mounting tabs on the fork lowers on the opposite side of the caliper mounting tabs???
The KZ900-B1 LTD has dual front disks with rear mounted calipers. Plus dual brake lines (with tee fitting) and larger 5/8" master cylinder (instead of the 14mm m/c used with single disc). And a slightly longer speedo cable.
Am thinking LTD dual disks are slightly thinner.
Dual disc system adds some unsprung weight.
Good Fortune! :)
  • mtbspeedfreak
25 Feb 2011 12:28
#433377
EXACTLY what I'm talking about!!! I think I saw them on dutchz's latest masterpiece as well.
What would go into inverting the forks? Just a longer speedo cable? You really wouldn't NEED a longer one, would you?
2000 ZRX 1100
  • andy9802gt
25 Feb 2011 12:50
#433388
Those are on the back of the leg, why would you need a longer speedo cable?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
