Mounting tabs on fork lowers
- mtbspeedfreak
24 Feb 2011 14:22
Hey guys, easy question for y'all:
What are the single mounting tabs on the fork lowers on the opposite side of the caliper mounting tabs???
I'm looking into a dual disc conversion and I'd invert the forks to swing the calipers around so they are underneath the lowers.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- MFolks
Re: Mounting tabs on fork lowers
24 Feb 2011 14:50
I believe they act like the rear brake torque link does. It prevents the caliper from rotating when brakes are applied.
- mtbspeedfreak
24 Feb 2011 14:56
Nothing is attached to these mounting tabs. I've seen a few instances where the tabs are actually ground off to make everything cleaner.
2000 ZRX 1100
- andy9802gt
- If it tastes that good, eat it yourself.
24 Feb 2011 15:09
reflector mounts maybe? Post a picture so we can see what you're talking about.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- mtbspeedfreak
24 Feb 2011 15:10
A picture is worth a thousand words.
I'll take a picture and post when I get home from work this evening. Probably get rid of a bunch of confusion
2000 ZRX 1100
- PLUMMEN
24 Feb 2011 15:18
fender supports for kz650
- z1kzonly
24 Feb 2011 15:21
Z1R's had them also. Just a factory thing. Different models used them for a fender bracket.
Production parts, multi fit.
I have a set ground off. Then I just looked in my junk pile and seen them on opposite sides.
- z1kzonly
24 Feb 2011 15:30
- z1kzonly
24 Feb 2011 15:37
24 Feb 2011 15:40
mtbspeedfreak wrote:
The KZ900-B1 LTD has dual front disks with rear mounted calipers. Plus dual brake lines (with tee fitting) and larger 5/8" master cylinder (instead of the 14mm m/c used with single disc). And a slightly longer speedo cable.
Am thinking LTD dual disks are slightly thinner.
Dual disc system adds some unsprung weight.
...What are the single mounting tabs on the fork lowers on the opposite side of the caliper mounting tabs???
- mtbspeedfreak
25 Feb 2011 12:28
z1kzonly wrote:
EXACTLY what I'm talking about!!! I think I saw them on dutchz's latest masterpiece as well.
What would go into inverting the forks? Just a longer speedo cable? You really wouldn't NEED a longer one, would you?
2000 ZRX 1100
- andy9802gt
25 Feb 2011 12:50
Those are on the back of the leg, why would you need a longer speedo cable?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
