Frame welding opinions, please.
- Mcdroid
- Gone Kwackers
21 Feb 2011 07:02
I'd like those with frame repair/welding experience to chime in on whether or not this is a repairable split. To orient you, it is the bottom of a KZ1100-B2 frame at the point the side stand attaches. I have not seen the frame in person, and only have this photo...I'm considering buying the frame, but only if it can be welded. Thanks.
Michael
Michael
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- testarossa
Re: Frame welding opinions, please.
21 Feb 2011 07:26
I'm sure it can be fixed. The way I would go about it is to progressively remove small sections of the tube on either side until I discovered solid tubing again. Then a new section of tubing will need to be welded in place. I would also weld in some strengthening slugs inside the tube at the points where the replacement tubing meets the existing frame tubes.
I hope you're getting a good deal on this frame. Are KZ1100 frames that hard to come by? If you could find a solid one it might be cheaper in the long run to get one that doesn't need to be repaired. Looks like someone with a tube bender would have to be involved.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
21 Feb 2011 08:32
thats rust damage,if its bad there id be willing to bet theres other bad areas.
i wouldnt fix it myself,maybe worth having for a title and steering head if its free but not an exotic collectors piece in my book anyway.
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
21 Feb 2011 09:13
PLUMMEN wrote:
really plummen.....rust damage? Nooooooooo.thats rust damage,if its bad there id be willing to bet theres other bad areas.
21 Feb 2011 09:23
i would not hesitate to repair it.
but that is kinda my thing,re-using junk :laugh: .
it is all repairable it just depends on how far you want to go.
21 Feb 2011 09:34
As Plummen said, if that's the result of rust it's likely that other sections of the frame may be rusted even though the rust is not visible on the outside. If it's not rust, did it happen as a result of an accident or other impact that may have bent the frame? I've never seen a frame just split like that from normal use, but I guess anything's possible. Ed
- PLUMMEN
21 Feb 2011 09:34
im into junk too,have ya seen my collection of model A's? :laugh:
but im at the point in life where ive learned to do a better job of picking my battles,if that was an early z1 frame or a z1r frame me and the garbage man would be rolling on the ground fighting over it! :woohoo:
- hocbj23
- trianglelaguna
21 Feb 2011 09:47
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
21 Feb 2011 09:48 - 21 Feb 2011 09:51
me and the garbage man would be humping
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 21 Feb 2011 09:51 by trianglelaguna.
- trianglelaguna
21 Feb 2011 09:49
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
21 Feb 2011 09:49
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
