Lester wheels
- mtbspeedfreak
Re: Lester wheels
01 Mar 2011 17:25Did Lester make cast magnesium wheels too? I'm assuming the Morris mags and Enkei's are aluminium as well?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
Re: Lester wheels
01 Mar 2011 17:27
mtbspeedfreak wrote:
I should add I "borrowed" that from Kawickrice on his Vintage Advertisement thread: kzrider.com/index.php?option=com_kunena&...w&catid=13&id=352699
2000 ZRX 1100
- mtbspeedfreak
Re: Lester wheels
25 Jun 2011 15:47
As long as I have the 6-bolt Z1 rotors, I can use a Z1 front Lester wheel on my KZ900, correct? The rotor/caliper spacing remains the same, just the bolt pattern is different- right?
2000 ZRX 1100
- trianglelaguna
Re: Lester wheels
25 Jun 2011 19:43
yes on the rotor offset and the only thing is mix and match on the speedo drives and nuts to end up working with cable you have now and the speedo gear on your axle
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mtbspeedfreak
Re: Lester wheels
25 Jun 2011 20:34trianglelaguna wrote: yes on the rotor offset and the only thing is mix and match on the speedo drives and nuts to end up working with cable you have now and the speedo gear on your axle
Thanks for the reply Tri, I didn't think of the speedo stuff. So if I bolt up a Z1 front wheel to my KZ, the Z1 discs would work with my KZ calipers, but I wouldn't be able to swap the KZ speedo drive? Is the axle the same?
2000 ZRX 1100
- trianglelaguna
Re: Lester wheels
25 Jun 2011 20:37
you'll see....depends ......it all works out
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- mtbspeedfreak
Re: Lester wheels
25 Jun 2011 20:46trianglelaguna wrote: you'll see....depends ......it all works out
Oh boy! Surprises! I HATE surprises! :laugh:
2000 ZRX 1100
- The Fish
Re: Lester wheels
26 Jun 2011 09:46 - 26 Jun 2011 09:48mtbspeedfreak wrote:trianglelaguna wrote: you'll see....depends ......it all works out
You'll need the Z-1 speedo drive (and discs)and the speedo drive will need to be machined down to center the wheel in the KZ forks (about 3mm). I dont remember the specifics (it was a long time ago) but you may need to make a new axle spacer for the other side also.
Z-1 Lesters on a 76 KZ 900
Last edit: 26 Jun 2011 09:48 by The Fish.
- roy-b-boy-b
- mtbspeedfreak
Re: Lester wheels
26 Jun 2011 15:41
Johnny's Vintage Motorcycles was selling a rear for a But it Now of $550! They didn't accept my offer of $350.
2000 ZRX 1100
- mtbspeedfreak
Re: Lester wheels
20 Jul 2011 03:35
Are Lester's tubeless?
If I can make a normal spoked rim into a tubeless tire with a rim strip and silicone, why WOULDN'T they be?
2000 ZRX 1100
Re: Lester wheels
20 Jul 2011 07:56It's dangerous to run without using a tube on a wheel that's designed for using a tube.mtbspeedfreak wrote: Are Lester's tubeless?
Some folks may get by with doing so, but under certain conditions the tire may suddenly deflate, such as when hitting a large bump while leaned over in a curve with insufficient air pressure.
Attachment tubevtubelessrimtxt.JPG not found
