Pull back brack brackets
  • Ou812cs
  • Ou812cs's Avatar Topic Author
17 Feb 2011 11:04
#431268
Anyone have set of pull back brackets to relocate bars to lower forks
Re: Pull back brack brackets
17 Feb 2011 12:23
#431284
:unsure: Uncertain about the part described as set of pull back brackets, and how relocating bars might lower forks. :unsure:
Does this by chance refer to handlebar risers, or possibly handlebar set-back risers? :unsure:
Good Fortune! :)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
17 Feb 2011 14:04
#431312
i'm thinkin he means clip ons.:huh:
  • dejavoodo41
  • dejavoodo41's Avatar
17 Feb 2011 19:28
#431410
The make pull back risers that are angled and bring the bars back toward the rider. You see em a lot in the HD crowd especially on the chops that are running an stretched backbone frame. They come in different heights and degrees of pullback.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
