rear brake LTD?
- BSKZ650
rear brake LTD?
27 Apr 2006 06:08
Ok, I got the rear brake caliper off with out taking the wheel off, wasnt that bad, dont think I can get it back together that way. the book I bought is for the kz1000, so the brake set up looks differant than LTD, what is the correct way to reassemble after I rebuild the caliper??
77 ltd1000, current rider
76 kz900, just waiting
- ejshotgun
Re: rear brake LTD?
27 Apr 2006 06:24
I ran into the same issue w/mine (it didn't disassemble anything like the manual said mine said the pads should have pulled from the top of the caliper and they couldn't because the caliper housing was a solid unit) and had to take it too the shop because I didn't have anyway to remove the rear wheel.
They had to remove the rear wheel and use air pressure to remove the pads and then reassemble on the bench then place it on the bike then replace the wheel.
They said it had to do w/where the bike was manufactured. Since it didn't cost that much ($40 bucks, but they said it would cost more the next time :laugh: but I got a jack now and I'll struggle w/it myself next time). You might give Jeff @ Z1 a call and ask him about this issue.
Post edited by: ejshotgun, at: 2006/04/27 09:27
- wireman
- ltdrider
Re: rear brake LTD?
27 Apr 2006 07:40
Here's the page from the LTD Manual that shows removal of the caliper. It says that dis-assembly/repair of the caliper is the same as the front, which is in the KZ Shop Manual.
Hope this helps.
Post edited by: ltdrider, at: 2006/04/27 10:42
Hope this helps.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- ltdrider
Re: rear brake LTD?
27 Apr 2006 08:02
Here's the brake caliper breakdown for the KZ900. It's for the front brake, but it should be the same as the rear.
Post edited by: ltdrider, at: 2006/04/27 11:03
Greensboro, NC
Greensboro, NC
- BSKZ650
Re: rear brake LTD?
27 Apr 2006 15:02
the one I have is a one piece unit, not too bad to rebuild I hope, going to take it apart tonight from the looks os the fluid that came out of it I may need to get into the master cyl.
Think while I am doing this then I am going to change it over to dot 5
still not real clear on how to reasemble the caliper to the bracket and get the pads in, may take a cold one or two to figure it out
- ejshotgun
Re: rear brake LTD?
27 Apr 2006 16:13
Just like BSK stated and I alluded too, it's a single unit.
Heck you know how it is, Guys, you got to have OJT (On the Job Training)
:lol:
:lol:
