Speedo Cable
- dms_photo
Speedo Cable
15 Feb 2011 07:56
When I got my new bike, the speedometer had been taken off. I tried to put it on yesterday, but the cable won't stay inserted into the drive. On the drive end of the cable, there are 2 prongs which look like they just slide around a pin which is inside the drive. I can get it to go inside, but it just falls right out. How should this attach? Is there some other thing that should hold it in there?
- dejavoodo41
Re: Speedo Cable
15 Feb 2011 08:47
there should be a threaded collar that screws onto the speedo drive to hold the cable in place
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- dms_photo
Re: Speedo Cable
15 Feb 2011 09:12
ahh, ok... I see it now. The previous owner apparently broke the colar off and it is still on the speedo drive. While trying to put the old cable on, I couldn't tell if something had been there or not. alright, off to order a new cable. Thanks for the help.
- z1kzonly
Re: Speedo Cable
15 Feb 2011 15:32
What type and model bike?
I have a pile of Z1-KZ- Jmodel-CSR 1000's.
I might have what you need.
Marty in Buffalo.
Marty in Buffalo.
