stem bearings
  • Stu Pidasole
  • Stu Pidasole's Avatar Topic Author
  • if you aint mod'n, you aint rock'n!
stem bearings
15 Feb 2011 07:20 - 15 Feb 2011 07:21
#430818
hey guys. i have some all balls racing stem tapered bearings from Z1e. leon sent out my triples and they should be here thursday evening. i have never installed bearings for the steering. all i know is that they need to be "pressed" in evenly. not sure about where to add grease exept for the bearings themselves. any tips would be great, or maybe even a link to a video showing tapered bearings install. thanks Joe
Last edit: 15 Feb 2011 07:21 by Stu Pidasole.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: stem bearings
15 Feb 2011 09:07
#430846
find a piece of pipe that fits pretty close around the stem and start tapping,damn i should write porn scripts! :woohoo:
  • DoubleDub
  • DoubleDub's Avatar
Re: stem bearings
15 Feb 2011 09:16
#430851
That's basically it. Just be careful where the pipe it putting pressure. I believe you want it to push on the inner race only? It's just a snug metal on metal fit. The top one will be much easier to install than the bottom bearing set.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: stem bearings
15 Feb 2011 12:28
#430874
pack the bearing cones with grease.
plummen,you mean you don't write porn scripts?:ohmy:
  • PLUMMEN
  • PLUMMEN's Avatar
Re: stem bearings
15 Feb 2011 12:41
#430878
only classy ones in my head,not like those soap operas that omr and larry write! :woohoo:
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: stem bearings
15 Feb 2011 14:44
#430898
So you write the ones gay guys watch?:ohmy:
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Re: stem bearings
15 Feb 2011 15:08
#430903
  • PLUMMEN
  • PLUMMEN's Avatar
Re: stem bearings
15 Feb 2011 15:23
#430906
no i leave those to omr/craig! :laugh:
