Can KZ 550 or 440 mags bolt right on to kz650?
- elcid
26 Apr 2006 20:54
I want to switch my spoked wheels to 7 spoke mag wheels & want to find the ones that bolt on with the least amount of mods. Will the kz 550 or 440 be a good choice? I have a 79 KZ650 B...
- loudhvx
Re: Can KZ 550 or 440 mags bolt right on to kz650?
27 Apr 2006 00:36
What about the 7 spoke mags from a 650? They had them starting in 1977. They used tubes, though.
The 550's were tubeless, but I don't think they are a direct bolt-on for you.
Post edited by: loudhvx, at: 2006/04/27 03:36
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- steell
27 Apr 2006 09:27
There is a Kawasaki wheel bearing list in the FileBase that lists what bearings fit what bike. If the 440/550 and 650 bearings are the same number it makes things a whole lot easier.
Post edited by: steell, at: 2006/04/27 12:28
- rstnick
27 Apr 2006 10:45
I have a front and back mag from a '79 C3. Where are you located? Shipping can be expensive. I'm North of Toronto ON, Canada.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- elcid
27 Apr 2006 10:54
yeah that may be a bit high for me. I am in Los ANgeles. Unless I can get them for less than $50 shipped, then it would not be worth it for me. Thanx though!
- elcid
28 Apr 2006 11:38
did the mags from kz650 have a rear hub brake? Something tells me they had disc setup. Now is there any major difference in the mags from kz440 or kz550? Is one belt drive & the other chain? any differences?
- steell
28 Apr 2006 12:12
I know the 80 KZ650F had mags with a rear drum brake, don't know for sure about any others.
- elcid
28 Apr 2006 12:20
Damn I need those! Were they 16 on back & 19 on front?
- elcid
05 May 2006 00:35
oops -wrong thread..
Post edited by: elcid, at: 2006/05/05 03:37
- 77_650B1
05 May 2006 10:08
I've been looking, and the wheels from an 82 kz550, at least the rear ones, would fit perfectly on my 77 KZ650. The damper, brakes, and spacers are all the same.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- elcid
05 May 2006 10:18
you can look at axle sizes here to see what is compatible:
www.hortoncustoms.net/hardcore/viewforum...7761deb4437923eb9a11
I got these kz400 mags & the back swaps fine but the front had a smaller axle. So I had to get different bearings with a spacer made to fit. It is a bit of modding but that is the name of the game...
