Sprocket Sizes HELP
  • amele7
  • amele7's Avatar Topic Author
Sprocket Sizes HELP
12 Feb 2011 08:12
#430181
Building a KZ1000 street/stip bike and need suggestions on sprocket sizes. Going with 530 chain, but not sure what gear ratio would be good. Any suggestions???
'79 KZ650B3
'81 KZ1000J
  • MFolks
  • MFolks's Avatar
Re: Sprocket Sizes HELP
12 Feb 2011 09:19
#430189
I use www.gearingcommander.com when changing sprocket ratio's.
12 Feb 2011 11:40
#430220
Some more good info:
Click > www.z1enterprises.com/reference/chain630to530.aspx
Good Fortune! :)
  • big mike
  • big mike's Avatar
12 Feb 2011 11:49
#430221
well on my drag bikes i run a 15 42 with the stock trans gears rear tire is a 26 in tall tier also
  • dblhdr
  • dblhdr's Avatar
12 Feb 2011 12:32
#430223
This is some info I got from "Bakes" at Z1 Enterprises, Inc. when I converted to a 530 chain.
17 tooth front - part number 249277
40 tooth rear - part number 249634
112 links of good quality 530 O ring or XW ring chain!
This yields a 2.35 drive ratio which is as close as you can get to stock
530 (JTF513 series) 17T front sprocket
EM95-47317
OEM: 13144-1009
17T Front Sprocket for 530 chain. Fits Kawasaki KZ650 (77-80), KZ750B KZ750G ZX750F KZ750H ZX750J ZX750K ZX750L ZX750M ZX900B.
Fits Z1, KZ900 & KZ1000 when converting to 530 chain.
40T Steel Rear Sprocket for 530 chain. 6-bolt with 80mm center, 52mm between adjacent bolt hole centers
Fits Kawasaki KZ550C KZ550D KZ550H KZ650C KZ650D KZ650E KZ750M KZ750G KZ750B
Fits the following for 530 chain conversion: Kawasaki KZ650H (81-83) KZ700 KZ750E (80-83) KZ750R KZ750H KZ750L ZX750 (80-85) KZ1000 (77-01) KZ1100 ZX1100 (83-84)
LA530XSOZ1-112 RK
530 Chain - RK 112 link 'X' Ring
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
  • TexasKZ
  • TexasKZ's Avatar
12 Feb 2011 14:18
#430240
The ratio you need depends on a host of variables.
Stock trans gears?
Power band of your particular engine?
Type of frame used?
Rear tire size and type?
Rider weight?
1/4 or 1/8 mile?
et cetera
  • dejavoodo41
  • dejavoodo41's Avatar
12 Feb 2011 14:45
#430247
I'm running a 17-42 setup and that puts me at 5k RPM @70 MPH. I'm actually thinking about going down in the back since I ride the freeway pretty regularly
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
12 Feb 2011 14:46
#430248
im ganna use 17-41 with 530.
  • amele7
13 Feb 2011 15:33
#430483
unfortunately I dont know anything about the motor...the guy I bought the bike from didn't know much other than he thought the guy who originally built it made the motor a 1075 but i dont know at this point.
Going to run 190 shinko rear tire 17in rim
I weight about 180 and would run the bike in the 1/4 mile...mostly for fun on test/tune night and still ride it on the street.
a friend of mine just gave me a 16 tooth front so I may go with a 39 rear thats roughly about the same as 17-41
thanks for all the info
'79 KZ650B3
'81 KZ1000J
