caliper seal rings
- andy9802gt
- If it tastes that good, eat it yourself.
caliper seal rings
11 Feb 2011 20:09
I need them if you have them I'll buy them. Need two 38mm ones for the front and a 42mm one for the rear. If you have some you don't need or want I'll buy them. Somebody has these out there. Let me know.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Re: caliper seal rings
11 Feb 2011 20:56
andy9802gt wrote:
Per Z1E listings:
Z1E kit for rear caliper includes the larger seal.
The smaller seal is available separately.
Click > www.z1enterprises.com/detail.aspx?ID=263
The smaller dust covers may be virtually disintegrated, and are important to keeping the "floating" articulation functioning smoothly.
Per Z1E listings:
- andy9802gt
12 Feb 2011 04:57
I've got the seals Patton, I need the metal ring that fits in the recess on the caliper to hold the dust boot on.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
12 Feb 2011 06:00
Check Kawasaki.com to verify part numbers, but I believe these are the parts you're looking for:
FRONT 43049-001
REAR 43049-002
FRONT 43049-001
REAR 43049-002
12 Feb 2011 06:06
andy9802gt wrote:
Am unfamiliar with such metal ring, and don't see it on kawasaki.com or in the FSM A4 caliper diagrams, but don't have FSM supp for LTD.
Here are the B2 caliper diagrams as shown on kawasaki.com:
[Click on image to enlarge view.]
12 Feb 2011 06:19 - 12 Feb 2011 06:21
Patton wrote:
According to Ma Kaw, on the front caliper picture the item labeled "15" is part number 43049-001; on the rear caliper picture the item labeled "12" is part number 43049-002. See my previous post for NOS eBay items. Ed
andy9802gt wrote:I've got the seals Patton, I need the metal ring that fits in the recess on the caliper to hold the dust boot on.
Last edit: 12 Feb 2011 06:21 by 650ed.
- z1kzonly
12 Feb 2011 06:23
andy9802gt wrote:
You must be talking about the steel retaining ring, that got burned up in that chrome process you were describing earlier??
That is gonna be hard to find, You need to get a bad caliper body with an unusable bore. Then carefully pop that ring out.
I might have to do that also, get specs and make stainless replacements.
Marty in Buffalo
Marty in Buffalo
12 Feb 2011 06:54
650ed wrote:
Yes, these are the same part numbers noted at www.z1enterprises.com/detail.aspx?ID=263 , and which I also first thought (incorrectly) were the parts desired.
Am no stranger to caliper overhauls, but never noticed or paid much attention to the subject metal ring.
This section from the FSM does mention a dust seal stopper.
Patton wrote:andy9802gt wrote:I've got the seals Patton, I need the metal ring that fits in the recess on the caliper to hold the dust boot on.Am unfamiliar with such metal ring, and don't see it on kawasaki.com or in the FSM A4 caliper diagrams, but don't have FSM supp for LTD.
12 Feb 2011 07:01
Very interesting. If they were attached to the calipers when sent to the chrome plater and he removed them I wonder what he did with them. It might be worth asking him if he still has them. Ed
- tybolt99
- From where KZs came
12 Feb 2011 10:28
I have one of 43049-002 off from KZ900A4 front caliper. Should fit on your rear caliper.
Drop me your address in PM if you want it, I will put it in the mail.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
