fork oil substitutes?
- gane
Re: fork oil substitutes?
06 Feb 2011 15:08
Lots of differing opinions, Please allow me to throw gas on the flame....The Valving on most "conventional" shocks is simply the diameter of hole in the "damper rod" located in the lower fork leg inside he fork tube.allowing oil to re-locate from the inside cavity of tube & lower leg up the fork tube. Oil quantity & viscostity determine rate of travel & amount. Honda (most noticibly)on many models used & rec'd ATF (which in the day was @ 5W)& was easily recognised in exiting by its cherry red color, ATF in the day, had some nice qualities... It retained its viscosity for 1, & had a low surface tension (the bubbles broke up ) thus resisted "foaming",Bel-ray Marketed for years, & still may, "seal with swell" an additive which may or not keep seals soft.& were avail. in multiple viscositys & allowed mixxing for fine tuning....Then came Anti-dive...Which in most instances became worthless with conventional fork oils in short order. Thus the change by many to conventional eng oil (20/50 whatever) which was thick enough to make the Anti-dives work.. use what you will, Just know why...G
[img][/img] 1977 KZ1000A1
- otakar
06 Feb 2011 18:08 - 06 Feb 2011 18:13
I like using Synthetic ATF I also agree about changing it at a minimum of every 10K miles.
Here are some general characteristics of ATF.
ATF Viscosity Characteristics
Product SAE Viscosity
Dexron II & Type F 5W-20
Dexron III, Mercon V & ATF Plus 4 0W-20
Caterpillar Powershift 10W, 30 & 50
ATF Frictional Characteristics
Product Fluid Characteristic
Chrysler ATF Plus 4
(AMSOIL ATF) Moderately Slippery
Dexron II & III, Mercon V
AMSOIL ATF) ) Slippery
Ford Type F, TO-4
(AMSOIL CT Series & ART) ) Grabby
Obviously you want to stay away from the "Grabby" ones.
Chrysler ATF Plus 4
Ford Type F, TO-4
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Feb 2011 18:13 by otakar.
