fork oil substitutes?
  • OnkelB
  • OnkelB's Avatar
Re: fork oil substitutes?
04 Feb 2011 08:11 - 04 Feb 2011 08:12
#428388
I used ATF in the forks on my old Honda 500 - actually that was what the factory manual recommended for that particular bike.
Only downside to ATF is that after a couple of years of use it'll stink like you wouldn't believe - when I took the Honda forks apart to change the seals I almost puked.
Btw, for both my KZs I use fork oil...
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 04 Feb 2011 08:12 by OnkelB.
  • testarossa
  • testarossa's Avatar
04 Feb 2011 08:15
#428390
That GS750 that I just bought says that ATF is an option for fork oil as well.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • steell
  • steell's Avatar
04 Feb 2011 09:32
#428410
TerryK wrote:
The way I see it, why use anything other than the recommended product? The factory designed the parts to use a specific oil and thats good enough for me. Other than cost, I see no reason to change.
And yet your sig says:
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
34mm Mikuni flat slide carbs
Dyna S ignition
Lockhart oil cooler
Wiseco pipe
I don't believe those are Kawasaki "Factory designed" parts :laugh: :laugh:
You think a 100 lb rider requires the same wt fork oil as a 300 lb rider?
  • Frankn9
  • Frankn9's Avatar Topic Author
04 Feb 2011 14:04
#428474
OK, I think I got what I needed. I think I'll try the synthetic motor oil for now. Thanks(to MOST of you);) !
  • notaduc
  • notaduc's Avatar
04 Feb 2011 15:37
#428493
Why not fork oil?
1980 (mostly) KZ1000
  • Frankn9
04 Feb 2011 15:57
#428501
mile and a half of ice and snow just to get to the main road from there the closest bike shop is about 18 miles. closest auto part store is about 10 minutes away! may be able to get the girlfriend to pic it up on her way home!
  • bountyhunter
  • bountyhunter's Avatar
04 Feb 2011 16:56 - 04 Feb 2011 16:58
#428521
One thing I found out the hard way is that viscosity numbers for fork oil and auto motor oil are not on the same scale. Once upon a time I blended some motor oil with some 10W fork oil to get it "a little stiffer" and ended up with forks that were ridiculously hard and like to loosen my teeth. To make life simple, I just use the 15W fork oil which seems perfect for street riding.
Last edit: 04 Feb 2011 16:58 by bountyhunter.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
04 Feb 2011 17:17
#428534
Patton wrote:
Or just run 'em dry to prevent leaks. :lol:
+2. My other personality agrees with you too.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • andy9802gt
04 Feb 2011 17:19
#428540
And you need fork oil right now because why? It's not like it has to be in there for you to sit on it and make engine noises.....vrooom, vrooom, vrooom.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • TerryK
  • TerryK's Avatar
04 Feb 2011 18:47
#428591
1977 KZ1000
WM6 rear Akront rim
Dyna S ignition
Lockhart oil cooler
Wiseco pipe
So what is your point? We're talking about oil, not parts. I use what's recommended and see no reason to change. I didn't say not to use after market parts, I just said I use factory recommended lubricants. Also, who said anything about using different weight fork oil? Any moron knows you have to use different weight oils for different weight riders and conditions.
Next time, maybe you should re-read what people type before you take shots.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • steell
  • steell's Avatar
04 Feb 2011 21:36
#428634
TerryK wrote:
1977 KZ1000
WM6 rear Akront rim
Dyna S ignition
Lockhart oil cooler
Wiseco pipe
The manual specifies the fork oil weight, and you're saying to use the specified lubricants, so if you're not saying anything about fork oil weight, then you're not saying anything at all.
Pointing out the irony of someone with a seriously modified bike saying to use the manufacturers recommended fluids is not "taking shots". Maybe you need to develop a sense of humor :)
  • TerryK
  • TerryK's Avatar
04 Feb 2011 22:46
#428647
steell wrote:
TerryK wrote:
1977 KZ1000
WM6 rear Akront rim
Dyna S ignition
Lockhart oil cooler
Wiseco pipe
Actually it is. All I did was share my opinion (which the OP asked for) and you decide to twist shit around into something it wasn't intended to be. Try to add some quality to the thread rather than trying to make someone look stupid. (other than yourself)
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
