front caliper ?
  • Kawbeach749
  • Kawbeach749's Avatar Topic Author
front caliper ?
26 Apr 2006 04:40
#42752
I bought caliper rebuild kits for my bike, and have everything together ok, but. The kits came with four small o-rings, perfect size to fit on the two bolts that the caliper slides on. But when I tighten the bolts the o-rings on the outside of the caliper squeeze out from under the bolt head. No info in the cylmer manual on brake rebuilds, and I cant find info anywhere else. Any ideas? When I just snug up the bolts the o-rings stay in place, when I tighten them real tight they squeeze out. help!thanks
  • fixer5000
  • fixer5000's Avatar
Re: front caliper ?
26 Apr 2006 06:10
#42766
those o rings go inside the caliper slides!! pull off those little dust boots and get a light and look inside the slide tubes..get a pick and remove the old ones. slide in the new ones, grease em up slightly and reassemble the calipers....steve
1978 kz650b pretty much stock
massachusetts
